Coilovers for 996TT
Old May 20, 2014 | 10:13 PM
dkfx's Avatar
dkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond repute
Thank you!
Billstein / Koni does factory shocks on hundreds of cars, including my previous M5....which suspension lasted around 60k before SIGNS of going... Why would their coilovers / aftermarket components be any different?
Originally Posted by Nikolas
Rebuilding every 2 years is either extreme track use, or crappy coilovers.
I have PSS9 on my 964, street use only, and there are no signs of leaking or degrading in ride quality in 10 years.
My 996tt also mainly street use, has had Pss10 for 3 years and they are still like new.
The Pss10 was a huge improvement in overall ride quality.
Old May 21, 2014 | 06:53 AM
DaveSen's Avatar
DaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud of
Coil overs
Keep in mind some coil over set could potentially use parts from the OEM suspension, for example H&R's I installed used top hat and washers from my original car. Just something to watch for as you finalize a purchase. H&R RSS can be purchased new for roughly $1700, very stiff and planted for track, reasonable ride on good roads.
Old May 21, 2014 | 11:42 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
I used to run ps9's on my m3 for 4 years straight! that includes winter. never got rusted or sized -I dont think i would buy cheap coilovers- I have bad experience in the past/on different cars, leaking or cant adjust them anymore.
I think if you lower the car on h&r or eibach springs just an 1" it won't do any harm to stock shocks.
Old May 26, 2014 | 03:32 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
The cost to install them outweighs the value of a lower price.
Old May 27, 2014 | 08:34 AM
Sabarab's Avatar
Sabarab has a spectacular aura aboutSabarab has a spectacular aura aboutSabarab has a spectacular aura about
If you end up lowering your 996TT with coilovers, you won't have enough adjustment on the control arms and toe bars to properly align the car. You will have to spend another $1500 on GT3 2 peace arms and adjustable toe bars... Otherwise you will end up with an aggressive negative camber that will consume your tires every few K miles.
Old May 27, 2014 | 01:12 PM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
Not sure that I agree with that. I had the PSS9's installed, had the car corner balanced and aligned. The technician actually set my camber slightly less aggressive than the stock setting to protect against excessive inside wear. This could potentially have a slight decrease in handling - but probably nothing that I would even notice. Overall, the alignment is within recommended specs.
Old May 27, 2014 | 01:32 PM
Sabarab's Avatar
You got lucky if you could align everything. My car with the KW V3 just simply ran out of adjustment and was left with too much negative camber. With the shorter gt3 control arms it was easy to make the car perfect.
Old May 27, 2014 | 03:58 PM
pwdrhound's Avatar
The amount of misinformation that permeates these forums is vast. Depending on the amount of lowering, generally the only item you need are rear adjustable toe arms to adjust toe back to spec. You certainly don't need GT3 arms for a daily driver but they are a must if you are trying to get increased camber for a more track oriented alignment.
Old May 27, 2014 | 05:35 PM
Qcktrbo's Avatar
Qcktrbo is infamous around these parts
Thanks for all the information! I'm still deciding on which set,...either HR or KW? I am still okay with the idea of even getting a decent set used, but good quality! I just have to decide how low to set the car for daily driving. Thanks.
Old May 27, 2014 | 05:44 PM
Sabarab's Avatar
I agree that there is a lot of misinformation here... However, the GT3 arms or aftermarket arms are needed with the coilovers because they are shorter than the factory turbo arms and they allow more camber adjustments.
Here's a good thread on the topic-
https://www.6speedonline.com/forums/...-lowering.html
Old May 27, 2014 | 05:55 PM
pwdrhound's Avatar
Have you actually had both the split GT3 and stock TT arms in your hands and measured both? You do realize that the stock 996GT3 arms without shims are the same length as the stock TT one piece arm? To be perfectly accurate, at a minimum, you need to run the GT3 arms with a 1mm shim on the right side of the car and a 1mm Xenon leveling bracket shim on the drivers side. The shims on a GT3 LCA will allow you to lengthen the arm thus increasing camber, not the other way around. Adding 7mm of shims to each GT3 arm has the effect of increasing camber about 0.6-0.8º per side.
Old May 27, 2014 | 06:03 PM
Sabarab's Avatar
Sure, you can also be more creative by machining 2mm down from it, since it is a 2pc design.
Old May 27, 2014 | 06:15 PM
pwdrhound's Avatar
Yep that's them. As you can see they are both the same length. Now please explain again how the GT3 arms will get you LESS camber...
Like I said, there is a lot of misinformation out there. Caveat emptor..
Feelgood MD
Mar 24, 2016 09:35 AM
Feb 24, 2016 01:10 PM
mrmaass
Oct 9, 2015 01:32 PM
Lucid Moment
Sep 23, 2015 10:37 PM
sparks
Sep 8, 2015 03:03 PM
