Overboost and Limp Mode
Old Jun 18, 2014 | 10:54 AM
  #91
Originally Posted by scsponger31
The only code that is coming through is P1250 Boost Pressure Deviation, above limit.
It seems that the passenger side of the system is where the problem lies. GMG came to this determination by disconnecting the wastegates one at a time, while the car was on the dyno.
if they swapped turbos with wgs and problem is still there then it would not make sense...
they should log the car via durametric see whats actually happening...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 18, 2014 | 11:03 AM
  #92
scsponger31's Avatar
scsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to behold
Thanks Mark.
I may be asking the wrong question, but what could cause a turbo to seemingly not boost when the wastegate is unhooked?
Any particular values I should ask them to log?
Old Jun 18, 2014 | 11:14 AM
  #93
3rd gear pull WOT. From 2200 to 6500 rpm.
Rpm
Engine load
Ignition angle
Oxygen sensing lambda value bank 1 and bank2.
Setpoint lambda bank1 and 2
Boost pressure of sensor
Setpoint boost.
Old Jun 18, 2014 | 11:21 AM
  #94
Rpm
Engine load
Ignition angle
Setpoint boost.
Thanks Mark! They biggest problem with 3rd gear WOT is it typically goes into limp mode prior to completing the pull. SO FRUSTRATING.
Also, I may be asking the wrong question, but what could cause a turbo to seemingly not boost when the wastegate is unhooked?
Old Jul 2, 2014 | 09:31 PM
  #95
168's Avatar
168
168 is infamous around these parts168 is infamous around these parts
did you get this resolved?
Old Jul 3, 2014 | 08:29 AM
  #96
I actually just picked the car up last night!
The cause ended up being the DME.
GMG was awesome in how they handled everything.
Old Jul 3, 2014 | 08:50 AM
  #97
32krazy!'s Avatar
glad you got the car back in top shape danny!
Old Jul 3, 2014 | 09:31 AM
  #98
Thanks for all your help Steve!!
I just need to give her a bath and all will be right!
Old Jul 3, 2014 | 10:59 AM
  #99
'02996ttx50's Avatar
congrats! man that was as long journey!
Old Jul 3, 2014 | 03:52 PM
  #100
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
Do you have any information on what caused the DME to fail? Glad it all worked out and that you were pleased with GMG's work. They seem to enjoy a very good reputation. Best,
Old Jul 3, 2014 | 04:05 PM
  #101
rmc1148's Avatar
Got your response on other site and this is good news, I bet your relieved.
Old Jul 3, 2014 | 10:09 PM
  #102
No clue. I am going to send it to be repaired so hopefully I will learn something.
Super relieved and happy to have it back.
Thank you everyone for all your help!!
Old Jul 4, 2014 | 05:28 AM
  #103
rmc1148's Avatar
Did they give you a donor DME or did you buy another as I see your sending old out for repair.
Old Jul 4, 2014 | 09:29 AM
  #104
I bought a replacement but at this point having two seems like a good plan.
Old Jul 4, 2014 | 11:36 AM
  #105
it's incredible there isn't some diagnostic function of the pwis whatzit that might've given some indication the ecu was acting up. that might have saved you untold grief!?
bottom line is yer back up n runnin! if ya ever get up malibu way..
