Slight hesitation on low rpms
Old May 20, 2014 | 09:20 AM
p556guy's Avatar
p556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud of
Originally Posted by Thklinge
Changed the plugs as part of the previous major service. The local Porsche Center didn't have time to do them so I did it myself. The car was running fine back then so I didn't bother with the coils and didn't check the solenoid brackets either.
Did you gap the plugs before you put them in? Maybe you didn't get one of the coil packs seated properly?
Old May 20, 2014 | 06:43 PM
Thklinge's Avatar
Thklinge is infamous around these parts
Plugs were correctly gapped before installation, checked them quickly. If a coilpack isn't seated properly I guess it would throw a CEL for misfire, and not pull like a bull on WOT?
Old May 20, 2014 | 07:18 PM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
Dirty fuel filter? Just a swing at something not already mentioned.
Old May 20, 2014 | 07:41 PM
Thklinge's Avatar
Pretty sure it was changed at the last major, I'll check.
Old May 21, 2014 | 01:22 PM
rob001's Avatar
rob001 is infamous around these parts
Since you got a durametric cable, why not log it as described in the Durametric 101 post above and post it. Maybe someone can look at it to see what is happening during the hestation instead of throwing parts at it.
Old May 21, 2014 | 01:37 PM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
you have a durametric and you can clear failure codes?
check the speed of your o2 sensors ... ore disconnect your first o2 sensors and do a try without them
maybe your 02 sensors are old and slow....
Old May 21, 2014 | 03:40 PM
you bought the car like that right?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 21, 2014 | 04:05 PM
p556guy's Avatar
I believe he said the car was running fine until he swapped spark plugs.
Old May 21, 2014 | 04:10 PM
In his email to me he stayed it was like that from start. Thus trying to figure out the truth.
Either way, good plugs and gap them at .024 and fresh coils if needed. That's a start. Along with a correct boost leak.
That's what I would do.
Old May 22, 2014 | 01:12 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
[QUOTE=p556guy;4117572]If I recall there was a post where someone checked the MAF voltage, got good numbers, but still saw better results with a new MAF.
QUOTE]
Hei Thorstein! Fin farge du har der ! Det var meg som hadde hva som saa ut some en fin MAF, men etter jeg skifted var problemene (like som deg) borte. Jeg haaper det er like lett for deg! Lykke til. mvh Gaute.
Old Jun 1, 2014 | 07:38 PM
Thklinge's Avatar
c32AMG-DTM: Seems the last service swapped air filter for the engine and the coupe, the oil filter, but no fuel filter on the invoice. Not weird though, the service intervals for fuel filter is 80k km, and my car had the 100k km service. It's not expensive so I ordered one just in case.
rob001: Durametric log of third gear pull here: Durametric.xls. Note that the log is on a no-boost EPL software, I'm still waiting for a new one with more power.
winnigt2: Yeah, I got Durametric, no error codes at the moment.
MARKSKI@911tuning: No, the car wasn't like this when I bought it. It's gotten progressively worse.
p556guy: No, it was fine also after new plugs.
MARKSKI@911tuning: Plugs were from EPL, gapped and ready. Will swap coils though as I have them lying around. Did a boost leak test, held pressure fine on both sides.
ASLAN: I'll do this in English so everyone can join in. Swapped two MAFs, same result either way.
Old Jun 1, 2014 | 07:53 PM
What do you mean by held pressure on both sides. You do the whole system at once not each side. Are you doing this or someone else. That's wrong
Old Jun 1, 2014 | 08:13 PM
Thklinge's Avatar
Explained it in the email, but for history and the others contributing in this thread, here's a recap:
As I recall he plugged the turbo on one side, pressurized the other turbo, and plugged the pipe where the airbox sits in the engine bay.
Old Jun 1, 2014 | 08:35 PM
horsepowerfarm's Avatar
horsepowerfarm is infamous around these parts
I suggest checking the throttle jacking unit at your throttle body. Sounds like it is "lazy" to me.
Old Jun 1, 2014 | 08:47 PM
Thklinge's Avatar
I've cleaned it thoroughly, also cleaned the potentiometer inside. It was a bit of dirt, but not much. I did however notice that the middle plastic gear had a bit of play in the center. There is also a bit of play between the tooths on the three wheels so I not sure it matters much, but if I move the throttle-plate back and forth I can feel the play in the mechanism. During driving the spring should keep it tight though, right? Or perhaps I need a new throttlebody?
