Vendetta's 996TT Build
Old Aug 14, 2014 | 12:15 PM
  #31
dkfx's Avatar
dkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond repute
FWIW i ran stock wastegates with evo's 1bar k16 tune and it ran fine (for all 200 miles before i swapped turbos to something bigger lol)
Old Aug 14, 2014 | 12:22 PM
  #32
that sounds right... i bar TUNE on STOCK wgs... should run fine... add 1 BAR WGS to a 1 bar TUNE and see it go thru the roof...
those are two different things... on stock wgs with a 1 bar your maxing out the n75 valve duty cycle.. add the 1 bar wgs and you will run ALOT more boost...
then you start backing off the wgs pressure( to keep the peak boost within reason) but keeping the wgs open down low and makes the car laggy.. on and on and on... thus a proper tune is is required... been there done that
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 14, 2014 | 12:43 PM
  #33
'02996ttx50's Avatar
Originally Posted by MARKSKI@911tuning
on stock wgs with a 1 bar your maxing out the n75 valve duty cycle.. add the 1 bar wgs and you will run ALOT more boost... then you start backing off the wgs pressure( to keep the peak boost within reason) but keeping the wgs open down low and makes the car laggy.. on and on and on... thus a proper tune is is required...
that fine tuning makes a helluva lot of difference. i just went thru a few weeks of tweaking them along with new check/n75 valves etc. finally back to a solid and modest sustained 1.3
but it's amazing how much difference 1/8 turns of the wg's adjust can make both good and bad.
Old Aug 14, 2014 | 01:16 PM
  #34
dkfx's Avatar
I'm assuming you are hooking some type of pump to the wastegate, then feeding it 14psi and making sure it opens then? is there a DIY on this? I wouldn't mind checking this everytime i changed the oil or something.
Old Aug 14, 2014 | 02:02 PM
  #35
yes. i'm sure there's a diy on it in here with pics. my buddy has the homemade job and ( obviously ) a compressor. we found my leak within the first minute. the check valve whistled lol. that was helpful
i wouldn't bother with it as a normal maintenance kinda thing ( unless your obsessive lol ) any more than i would check my ic hoses or tugging on the y-pipe, absent any obvious leak issue. i generally only search for issues if i suspect i have one. beyond that, just a rigorous maintenance schedule i've found works best for me.
but if you want to pressure test as part of maintenance? no one could fault you for it.
Old Aug 14, 2014 | 02:47 PM
  #36
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Good info guys!! Thanks!
1 bar = Overboost?!? Pft silly Porsche engineers! Bunch of Buzz Killington's over there!
Old Aug 14, 2014 | 04:11 PM
  #37
betonred's Avatar
betonred is infamous around these parts
it is raspy due to the catless system?
Old Aug 14, 2014 | 04:22 PM
  #38
32krazy!'s Avatar
remove the rubber line to the w/g hook up a mityvac and pressurize to 14 psi and watch the rod start to move. simplest way
Old Aug 14, 2014 | 04:27 PM
  #39
Vendetta's Avatar
Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !
Believe it or not, it's actually less raspy at idle than it was with the cats. But at wide open throttle it rips like crazy. I absolutely love it!
-V
vlocci
Nov 9, 2015 09:42 AM
Mr. C4
Sep 18, 2015 06:26 PM
TurboDragon
Sep 4, 2015 09:11 PM
