Steering Wheel Vibration
Old Jun 25, 2014 | 04:07 PM
caunyd's Avatar
caunyd is infamous around these parts
Hi guys. After switching to aftermarket wheels with new tires, I have noticed vibration in the steering wheel when driving on the freeway (there is no way that this steering wheel shaking is normal). I had the tires balanced with a hunter road force machine, but I still feel the vibration. What do you think is wrong? Thanks.
Old Jun 25, 2014 | 04:11 PM
rmc1148's Avatar
Check lugs for proper torque. If its not a bent wheel or bad tire it probably still balancing. Are the wheels hub centric?
Old Jun 25, 2014 | 06:11 PM
'02996ttx50's Avatar
new wheels suggest new alignment. i'm going with improper alignment.
Old Jun 25, 2014 | 06:47 PM
32krazy!'s Avatar
theres a painted dot on the sidewall. this dot should be aligned with the valve stem on the wheel. misalignment can cause a vibration.
Old Jun 25, 2014 | 07:32 PM
rmc1148's Avatar
Never heard of the dot but then I haven't personally mounted a tire in over thirty years lol=learned something new.
Old Jun 25, 2014 | 07:37 PM
seen the dot. always wondered lol
Old Jun 25, 2014 | 07:38 PM
2swoosh's Avatar
2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future
does the vibration occurs at all speeds or just certain mph?
Old Jun 25, 2014 | 08:36 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
My initial guess would be slight over inflation on the front tires. This, even with a balanced tire/wheel combination can induce and transmit vibrations to the steering wheel.
Tires may have a dot that either corresponds to the valve stem or 180 from the valve. It is color and brand dependent. It's really not important to line up the dot it just generally allows for less added weight when balancing.
Further, some roads with uneven surfaces will cause this in varying degrees. Adjust your tire pressures by the book, 36 F, 44 R then try a newly paved smooth straight road. If you still get wheel shake, take your car back to the people that mounted the tires and have the fronts removed and rechecked for balance.
Alignment generally will not cause this issue.
Old Jun 26, 2014 | 09:07 PM
caunyd's Avatar
Thanks for the input guys!
Nick they inflated the tires to Porsche specs, so I don't think it's slight over inflation in the front tires.
My wheels are Porsche replica wheels, so shouldn't they be hubcentric?
Old Jun 26, 2014 | 09:54 PM
nick49's Avatar
Did you check the pressure yourself and verify they are at 36 PSI cold?
Maybe hubcentric maybe not. If not, they can still be concentric when mounted if they are a good quality wheel, the PCD is very accurately machined and the bolts are evenly tightened.
Old Jun 27, 2014 | 01:35 AM
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
I doubt psi would cause vibration. Since the psi is evenly distributed within the tire, it sounds more like the tire/wheel is off balance.
If the wheels were used they could be slightly bent from hitting a very rough or intense pot-hole...
For reference, what wheels are they?
Old Jun 27, 2014 | 02:35 AM
Fasoole's Avatar
Fasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant future
Welcome to the Club!!!
Old Jun 27, 2014 | 10:42 AM
pterfloth's Avatar
pterfloth is infamous around these parts
I had this same problem after switching to Victor Equipment Innsbruck wheels. After several balancing attempts, it turned out that the problem was that the wheels were not perfectly hub centric. That was enough to cause the vibration at highway speeds. I took the wheels to a wheel repair shop, had them machined and hub centric inserts installed in the center hub. That made all the difference in the world and they are now completely vibration free at any speed.
Old Jun 27, 2014 | 10:54 AM
wross996TT's Avatar
Just another thought, since the rubber is new is it possible you were tramlining?
Old Jun 28, 2014 | 09:43 PM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
How old are your front tires? Do they have any scuffs around the perimeter either inboard or out?
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
Michael_s
Sep 11, 2015 08:03 PM
no1joey
Sep 2, 2015 12:32 AM
Zero911
Aug 24, 2015 06:51 PM
