Basemap from EPL ; k24/18gs
Old Jul 4, 2014 | 09:16 AM
dkfx's Avatar
dkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond repute
Originally Posted by Tim941NYC
Tony will get you there. You need to use a mighty vac in the psi setting and check the cracking psi of each wg. Yes you can adjust by simply loosening the nut between the waste gate and the arm then tighten the nut on the end till it cracks at 14-15psi then tighten up the first nut you loosened to the arm. I would guess it is just the gates are not adjust correctly.
I thought the minimum of the AMS wg's WAS 1 bar?
Old Jul 4, 2014 | 10:32 AM
32krazy!'s Avatar
a tad less. 1 bar=14.7 psi. w/g can be set at 14 psi. since your seeing .7 it could be a combo of leaks and improper setting or each alone. have to test and see where it takes you.
it only takes a single turn or 2 of the w/g arm to change the pressure its that sensitive.
theres no such thing as plug and play on these cars. each mod leads to different issues which may not have been readily visible before. its part of the fun!:roll eyes: take your time and start with boost leak testing as its probably not been done in a long time. then w/g adj and on and on
just my .02 but when tim941nyc speaks i listen! he is a wealth of knowledge and has forgotten more about building fast cars than ill ever know
Old Jul 4, 2014 | 10:45 AM
johnspeed's Avatar
When I first got his tune for my K24/18g set-up from him at way back when , there was a sheet he sent me with the cable and new spark plugs..
The sheet said to set the waste gates crack open point at 13lbs..
Good Luck
Old Jul 4, 2014 | 10:53 AM
dkfx's Avatar
to INCREASE the PSI on the wastegates, am I shortening or lengthening the rods?
Old Jul 4, 2014 | 11:01 AM
johnspeed's Avatar
Shortening them.
Old Jul 7, 2014 | 07:47 AM
32krazy!'s Avatar
Originally Posted by Tony@epl
Lets touch base today! .7 is very low for a 1 bar wastegate can! I heard your VM as well about stalling at idle, I'd defiantly start looking for leaks!
tony he is on a special car run across the midwest and may not log in for a few days. he isn't in his car until next week i believe
Old Jul 8, 2014 | 11:11 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
adjust your wastgates evenly till you see 1.0 thats it no worries!
Old Jul 9, 2014 | 10:51 AM
as usual get a pressure test on the car... and at the same time check the WGs... set them so they start to crack open at 15 psi.... between those two things you will find all your issues... but do a pressure test to 20 psi not a 7 psi smoke test.
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 9, 2014 | 01:09 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
talk with Tony and let him fix you up. He's the man!
Cheers,
Rob
Old Jul 23, 2014 | 06:40 AM
dkfx's Avatar
turns out I had a boost leak, problem resolved, and boosting on wastegate spring only at the moment (1 bar) awaiting to start the tuning process.
Just a quick question for those of you that have gone through EPL for tuning, you need to log with a durametric cable, correct? You can't use a generic or the flashing cable Tony sends with the kit? Just curious (and anxious to log).
Old Jul 23, 2014 | 06:11 PM
32krazy!'s Avatar
you need a durametric cable.
Old Jul 25, 2014 | 12:49 PM
your dureamtric cable should have been ordered and delivered by now. from when you started this thread half dozen guys posted the same thing . you need duramtric to log and diagnose ur car. it is a must for a modified car and its only 300 bucks. buy it, learn it and take guessing out of diagnostics.
#TeamAIM
Perrew
993 Turbo
Dec 9, 2016 08:35 AM
dkfx
Apr 21, 2016 01:58 PM
ship it
Sep 7, 2015 10:49 AM
