ABS PSM Error Lights
Old Jul 9, 2014 | 10:43 PM
brichacek's Avatar
brichacek is infamous around these partsbrichacek is infamous around these parts
No, I haven't checked for a boost leak. Haven't done that before so would need to read up on it.
Old Jul 9, 2014 | 10:53 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Markski has a good thread about it and what to get.
Old Jul 10, 2014 | 04:51 AM
glh's Avatar
glh
glh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud ofglh has much to be proud of
Originally Posted by brichacek
Just got the dreaded ABS and PSM error code lights...
Had this issue a while back.
Tried cleaning the MAF didn't fix it.
Changes the MAF and it fixed it.
I also went back to the paper OEM air filter as from what I read Oil Based filter tend to mess up the MAF.
Good Luck
Old Sep 8, 2014 | 08:47 PM
brichacek's Avatar
Just to update everything, finally fixed this issue. It turned out to be the MAF. I tried cleaning it with no luck. Changing it out for a new one solved the problem. Also got rid of the air filter and went back to stock
Old Sep 9, 2014 | 01:55 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
It's amazing the plethora of codes a bad MAF will randomly throw!
Old Sep 9, 2014 | 07:13 AM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
I didn't try that. Is it safe to disconnect the MAF cable and start the car?
The only error lights on now at the ABS and the PSM, and the same error code as previously. I've installed the 3rd brake light LED resistors (one on each cable).
The spoiler light went away after following the guide above and cutting out the sensors.
The fuel gauge fault went away after a full fill up of gas.
My MAF WENT and did this... ripped out my airbox and drove it without ABS and MAF disconnected the 55 miles to Tims... the new MAF I bought here on 6 speed was effed as well
I am going MAFLESS
Old Sep 9, 2014 | 07:25 AM
'02996ttx50's Avatar
ever since ( and the only time i ever switched a maf to a NEW bosch ) i have not had an issue once. ( back to paper filter tho.. )
stay away from refurb/tawainese or mafs of unknown provenance lol
alwaysbored786
Apr 19, 2016 05:51 AM
carwash
Sep 26, 2015 03:11 PM
hacellular
Aug 31, 2015 08:34 AM
GSR Autosport
Aug 26, 2015 05:20 PM
