just swapped plugs and coil packs and now getting missfire on cylinder 1
Old Jul 11, 2014 | 06:04 PM
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
Which cylinder is number 1?
Old Jul 11, 2014 | 06:28 PM
IITURBO's Avatar
Ok i did some research i found #1 to be drivers rear which was the easiest one to do and that doesn't make sense. I used a very little anti seize on the threads and a drop of dielectric grade pin the end of the could would that effect anything?
Old Jul 11, 2014 | 06:30 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
car had missfire before?
Old Jul 11, 2014 | 06:32 PM
Tim941NYC's Avatar
Maybe you did not get the connector all the way in? sometimes they are a bear..
Old Jul 11, 2014 | 06:39 PM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
Like Tim says. Check the clip. After that, I would swap it with another cylinder - both the plug and coil.
When you do, check that number1 plug is tight. I've heard if loose plugs that idle fine but miss at rpm
Also It's not the first time that I've heard of a new plug or coil that is bad.
Old Jul 11, 2014 | 06:41 PM
IITURBO's Avatar
No missfires before, im pretty sure i heard the connector click. And wtf is up with the passenger side front coil pack??? Did they make it that inaccessible on purpose?
Old Jul 11, 2014 | 07:19 PM
mtlsp's Avatar
mtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond repute
engine is firing 5cyl only? or occasional misfiring? maybe the plug gaping...
Old Jul 11, 2014 | 08:25 PM
IITURBO's Avatar
In the heat of the koment I must have forgotten to plug in coil pack number one, that problem is solved but now i have an abs and PSM issue now. Shoot me.
Old Jul 12, 2014 | 05:45 AM
Tim941NYC's Avatar
boost hose is off.
jaehoppa
Oct 22, 2015 09:17 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
ship it
Sep 7, 2015 10:49 AM
studio112
Sep 7, 2015 05:06 AM
