2001 TT with ignition problems - Please Help!!!
Old Sep 25, 2005 | 09:19 PM
Hungry4$$$'s Avatar
Hungry4$$$ is infamous around these parts
For the past month or so my 2001 TT has been having ignition problems. The car will typically only start the second time I try. When I turn the key to the right the first time the ignition does not turn over -- at all. Usually the second time the car will start normally.
Now, the key is stuck in the ignition and will not come out. I disconnected the battery so that it doesn’t die.
Does anyone have any idea what the problem might be?
Thanks very much in advance for your help!
Hungry
Old Sep 25, 2005 | 09:42 PM
AeroTT's Avatar
AeroTT is infamous around these parts
Hungry,
Sounds like you may have a bad ignition switch. You should bring it to your dealer to get it checked out asap. Good luck.
Old Sep 26, 2005 | 12:25 AM
KPV's Avatar
KPV
Mike,
Also try applying a turning force to the steering wheel as you turn the key to remove it. First try applying a force to the left and then to the right. That might allow you to remove the key.
Old Sep 26, 2005 | 11:18 PM
FUNNY, i have a 01 TT and just replaced my bad ignition switch..... my car started but the key was hard to remove/move.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
the5
Oct 14, 2015 06:46 AM
Zmydust
Sep 10, 2015 12:31 PM
sparks
Sep 8, 2015 03:03 PM
Just Cruise
Sep 5, 2015 07:53 PM
Suds26
Sep 2, 2015 01:33 PM
