Tim941nyc's 996tt daily driver build thread..
Old Aug 18, 2014 | 10:11 AM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Subscribed!
Old Aug 18, 2014 | 10:22 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Tim,
Lovin that Y-pipe with the BOV on the top there!!! That's on my list of things to fab up this year!!! Care to share the specs of it? 3" into 3.5" or 4"? Have you fab'd up your turbo intakes yet?
Scot
Old Aug 18, 2014 | 10:27 AM
TiKORE's Avatar
TiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of light
Good luck with the build, look forward to seeing more! #welugwheels
Old Aug 18, 2014 | 03:09 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
I love these build threads. Thanks for posting it.
Old Aug 18, 2014 | 04:33 PM
Tim941NYC's Avatar
This is a stock engine for now Paulie. I really want to replicate what the average build would be. I did weld the coolant lines add 997 coil packs and new plugs, why not throw in my 8mm ball mod on trans while I was in there. The car has a porsche factory ssk in it so that will stay. Here are some more pic's. Any questions ask away, I am trying to keep it pretty basic on mods but I cant help throwing some fab work at it!!
Air cleaners, They will get the K&N prefilter socks.
Passenger side center radiator line repair, you can see the weld.
Drivers side coolant pipe repair.
Old Aug 18, 2014 | 04:42 PM
Tim941NYC's Avatar
Thank you for the support guys. To answer some questions I like using Eurodyne maestro, it works! I have done a bone stock K24 car with injectors and fuel pump still on stock air box, inlet pipes and ic's and a awe exhaust that is doing 7.0 60-130's in 80-85 degree heat.
Old Aug 18, 2014 | 04:51 PM
Ursoboostd's Avatar
Ursoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to all
Cant wait to see more.
Old Aug 18, 2014 | 04:53 PM
32krazy!'s Avatar
no worries about water getting into the turbos tim? i was wanting to run something up along the trans out of the water path
i went between the ductwork for the i/c and the inside fender but i don't think theres much airflow in there
Old Aug 18, 2014 | 05:25 PM
Tim941NYC's Avatar
Not worried about water at all. The pre filters repel water, used to run them on jetski's with stainless steel mesh behind them. Never sucked water through them.
Old Aug 18, 2014 | 05:28 PM
32krazy!'s Avatar
ill keep this in mind! it would be the easiest way to get air in
Old Aug 18, 2014 | 05:38 PM
Tim941NYC's Avatar
Here are some more coolant line repair pic's and wye pipe pics.
ID:	399509   Click image for larger version
ID:	399510   Click image for larger version
ID:	399511   Click image for larger version
ID:	399513   Click image for larger version
Old Aug 18, 2014 | 05:50 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
How do those wiggins clamps work? Do you have to weld a lip to the throttle body and the Y-pipe?
Old Aug 18, 2014 | 06:40 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Looking good Tim. What HP/Tq are you hoping for?
Old Aug 18, 2014 | 07:42 PM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
That sounds very fast for stock K24s! Stock clutch in that car, or upgraded?
Old Aug 18, 2014 | 07:44 PM
c32AMG-DTM's Avatar
Good question, would like to know as well.
A2871's with that intake/Y-pipe design I'm guessing will spool like mad.
