EVOMS 996TT GT775 + Techart + Adv.1 - Build and Results
In the fifth inning of game three in the 1932 World Series, Babe Ruth came to bat and famously pointed towards center-left field, calling out the direction of his impending home run according to legend. Two strikes and one more taunting point later, he launched a line drive into the bleachers in center-left putting the Yankees up 4-1 towards a game win and eventual championship.
Some 82 years later, EVOMS customer 'TS' stopped by our Tempe, AZ showroom to visit and talk about what we could do to bring his 996 Turbo to the next level. Already equipped with the EVOMS GT660 Signature Turbo Kit, he was looking for more power and a more aggressive, unique appearance for the exterior of the car. He walked into our showroom, the walls of which are lined with photos of highly modified 996 Turbos we've built over the years. With a cool southern drawl, he pointed at the photos and told us 'I think those are pretty cool'. A couple months later, his own beast was completed and we'd hit one out of the park.
The foundation of TS' project was the upgrade to the GT775 Signature Turbo Kit. Going above-and-beyond the tried-and-true GT700 kit, the GT775 optimizes everything around the factory 996 Turbo longblock. Twin Alpha 28 watercooled ball bearing turbos breathe through an EVOMS V-Flow intake and EVOMS Turbo Inlet Ducts. Boost is handled by high flowing EVOMS Silicone Boost Hoses, cooled by our Clubsport Intercoolers, and funneled to the motor by a modified Y-pipe feeding a 74mm throttle body and the IPD Competition Intake Plenum. EVOMS Clubsport Exhaust Manifolds help spool the turbochargers and eliminate the choke point in the exhaust at high power levels. A Tubi street exhaust was chosen to make the car roar, will being practical and almost completely drone-free on the street.
To feed the fire of nearly 800hp, a newly evolved GT700 fuelling kit is used which includes high flow lines from the fuel tank to the motor along with a high flow fuel filter and new Injector Dynamics ID725 fuel injectors. EVOMS HED Ignition Coils provide the reliable spark needed at high cylinder pressures. Our Lightweight Underdrive Crank Pulley improves reliability at high power levels and lets a couple more ponies make it to the ground. An EVOMS Stage 3 clutch, Lightweight Steel Flywheel, and GT2 Slave Conversion rounded out the drivetrain modifications.
The hallmark of EVOMS Signature Turbo Kits is the power and driveability of our EVOMSit software and tuning. Upon completion, TS' car hit our dyno for final tuning on 93 octane pump fuel. The results were a massive 660whp and 675wtq, which equate to an estimated 775hp and 795ft-lb at the flywheel. On the street, the AWD 996 Turbo struggles for traction through third gear. The onslaught of torque from 3500rpm onwards is enough to break the tires free when accelerating from cruising speeds, and the linear top end power is enough to dust off almost anything TS might encounter on the streets of South Carolina.
Power and speed wasn't enough for TS; he wanted to stand out as well. With that, we worked with Elite Automotive Finishes and Techart to enhance his already pristine condition slate grey 996 Turbo with the GT Street front bumper and side skirts along with a GT2 rear wing and decklid. We choose Techart as they provide unmatched build quality and finish, along with a timeless design that still has presence over ten years after its initial release. The gloss carbon fiber spoiler, intercooler duct splitters, and top wing tie the car together from front to back. The final piece of the puzzle was a stunning set of 19" Adv.1 ADV8 Track Spec wheels with transparent brass centers and polished lips. The first of this style ever used on a Porsche, they are wrapped in 235/35r19 and 305/30r19 Michelin Pilot Super Sport tires.
For more information or to build your own beast, visit www.evoms.com or contact us at +1-480-317-9911 or info@evoms.com.
Special thanks to Mike Kuhn Racing for the excellent photography.
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Thanks! I know of a couple slate and atlas 997s, but this is the only 996 I've seen. It's such a 'deep' color, it really looks great especially once we put it on some real body lines with the Techart items. We had planned on respraying the car to match the new bodywork, but the guys at Elite were able to match the bumpers and decklid almost better than the factory did (plastic vs. metal parts), so we gave the car a good detail and did a full front clear bra.
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Gorgeous car and build! I've got 19x12 ADV.1's with the 305/30/19 PSS like you. Did you have to raise ride height at all to avoid inner fender rubbing on compression? Or do anything special with the alignment or fender brackets?
Thank you! The wheels were a late addition to the project, so those were installed by the owner when the car was already back in South Carolina. He was able to bolt them on straightaway though, and hasn't had issues with rubbing. The car is not super low (he is running PSS9s), and had 19x11 Champion wheels with the same height rear tires previously, so there may have been some modifications done for their installation, but we did nothing else. In my experience, there's a sweet spot where this combination works. Too low and you'll rub the fender lip. Too high and you'll rub where the intercooler hose goes. The most clearance is just in the middle.
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
beautiful car! congrad! does the gt700 and gt775 run same amount of boost ? any acceleration time ? 1/4 ,60-130?
"To feed the fire of nearly 800hp, a newly evolved GT700 fuelling kit is used which includes high flow lines from the fuel tank to the motor along with a high flow fuel filter and new Injector Dynamics ID725 fuel injectors. EVOMS HED Ignition Coils provide the reliable spark needed at high cylinder pressures. Our Lightweight Underdrive Crank Pulley improves reliability at high power levels and lets a couple more ponies make it to the ground. An EVOMS Stage 3 clutch, Lightweight Steel Flywheel, and GT2 Slave Conversion rounded out the drivetrain modifications."
Great job as always guys. Really digging the entire project! Regarding the new injector dynamics ID725 did you install adapters? My Gt700 has the upgraded fuel lines and the high flow fuel filter but on deka 60LBS with the HED ignition coils. Is it worth changing out the injectors?
