Oxygen Sensor
Ok I have a catalytic converter code. Comes and goes. Usually in damp conditions. Never in summer. I thought proceeding in the following order: 1. Check contacts (probably not it, or possible)? 2. Changing the sensors? 3. Anyone knows what makes are they? Can I get them direct I.e. Denso? 4. Fitting an emulator? Anyone done this? Finally, I have a tune. Would they disable oxygen sensors? How would I find this out? Thanks.
Agree about contacting tuner but you could also electro-clean contacts and put some dielectric grease on them. I always change mine at the 50k mark or when they act up= preventive maintenance. I usually go with Bosch or Denso.
Thanks mate. Do you have Bosch or Denso part number by any chance? Preference? Where to buy?
Don't know the tuner. Inherited the tune. Bummer. But the code wasn't there before so I am guessing sensors. Do they play a role in the tune?
The sensor should not be unscrewed until after the connector is separated.
My info why is the sensor breathes through its cable/lead and connector. It needs outside air to work and this air wants to be dust, moisture and contaminant free.
If the code points to the converter the usual course of action is to if there are any other codes -- could be a pending code too so read pending codes -- that point to "aging" O2 sensors to replace the sensors indicated and then clear the codes and drive the car. If the converter codes come back then replace the converters.
My Boxster generated a P0430 code most often in the winter months. I switched from using a discount gasoline to using Shell V-Power, which helped cut down how often the code appeared.
Some few months back I had the car in for something else and I asked the tech to find and fix the rattling heat shields. He reported back the shields were fine the noise was a converter rattling, its "brick" was loose. I suspected as much. But I was tired of the noise and the code coming back so I picked up two used converters and had him install them. (Before I bought the used converters I gave them a good shake test and confirmed both were quiet. I handled them with care too.)
This is not the source I was thinking of when I posted but this will do.
http://www.pelicanparts.com/techarti...-02_Sensor.htm
"911 Carrera 4 has a new, water-proof oxygen sensor. Water-proof means that the upper sensor section and housing are connected leak-proof with a later welded seam and previous reference air openings are omitted. Reference air is now taken via the connecting lead and plug connection. For this reason it is important to keep contact solutions, lubricants, liquids or similar products out of the 3-pin plug, since they would lead to sensor failure"
Yes you are correct about the air flow around wire sheathing but the connectors themselves can be cleaned and lightly greased. I have changed dozens of o2 sensors and have never had an issue but completely see your way of following rules.
Email all of the tuners and ask them if they have your VIN on their flash files... they will come back vey quickly... took me all of 2 days and 7 emails to find out my old tune
Yes my code is 0420. Yes I am getting it mostly in damp winter months. So is the oxygen sensor the most likely culprit? @ Macster, did your used sensor replacement did the job and stop the code? Thanks.
