boost question
Old Oct 18, 2014 | 04:26 PM
sparks's Avatar
sparks is infamous around these parts
I plan on bringing it to ya(markski) as soon as we can work out a time. Tune and leak check. Do ya do Saturdays ???
Old Oct 19, 2014 | 10:39 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
996TT 16K: max 0,7
996TT 24K: max 0,9
Its for sure a leak. The car should go in limb mode. Check with OBDII. you will find a P0234 error.
Looks like this.
https://www.youtube.com/watch?v=_Kk1...ature=youtu.be
My car is flashed and got a max boost of 1.1 bar with k16.
Old Oct 19, 2014 | 11:46 AM
sparks's Avatar
Does boost leak equal loss of horsepower?
Old Oct 19, 2014 | 11:48 AM
sparks's Avatar
Or if I am reaching 1.4 bars would that create more horsepower?
Old Oct 19, 2014 | 11:59 AM
If you dont want to pay for some new turbocharger, dont let them spin like crazy. The k16 and k24 are very strong, but wont take permanent beating.
The VTG`s in the 997 models are far more fragil.
Old Oct 19, 2014 | 01:21 PM
It is highly unlikely your car on k16s can run that boost. No stock k16 can do that with oem wastegates and that would be not healthy for your car on pump. Something is really not right be it a tune and or mechanical.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 19, 2014 | 03:31 PM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
no leak at the pressure side of the engine can give you more boost ......we all know you loose boost at this pipes if there is a leak
Its only possible you have a leak after the n75 valve to the wastegates .....(ore one wastegate is def of mechanical blocked.....)
Old Oct 19, 2014 | 04:58 PM
I've seen goofy stuff in the programming. But I'm guessing the n75 hose to Wg is leaking and it's not opening the flap. But s datalog to start with will tell the story.
Old Oct 19, 2014 | 06:01 PM
sparks's Avatar
Thanks, bringing it to Markski on Saturday .
Old Oct 19, 2014 | 07:06 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
sparks just dont boost it and let markski check it you be fine
Old Oct 19, 2014 | 07:11 PM
sparks's Avatar
Maybe just a little boost ! QUOTE=MadWhip;4218792]sparks just dont boost it and let markski check it you be fine[/QUOTE]
Old Oct 20, 2014 | 02:28 PM
GeeTee2's Avatar
GeeTee2 is infamous around these parts
Keep us posted anyway !
Old Oct 21, 2014 | 02:33 PM
If there is no leak, the wastegates are fine, and still the boost is doing crazy things, than the N75 Valve is toast.
Jul 29, 2019 11:13 AM
nlakind
Nov 6, 2015 10:15 AM
ECS Tuning - VW
Aug 28, 2015 11:48 AM
PelicanParts.com
Aug 26, 2015 04:25 PM
