boost question
Old Oct 17, 2014 | 06:55 PM
sparks's Avatar
sparks is infamous around these parts
boost question
Starting to get more comfortable with car now. Took it to 6k rpm and boost showed 1.4 . Is that normal ? Car has a tune(upsolute) and europipe on it. Seems to run fine. just don't want to hurt anything. thanks
Old Oct 17, 2014 | 07:14 PM
'02996ttx50's Avatar
Its a tad high if its a k24 car with a normal 1.2,tune. If its a k16,its too.much and you'd be smart to consider logging it and staying out of 1.4,for.long as you may have a leak or waste gate issue and that territory isn't right for a k16,only flashed car.
Old Oct 17, 2014 | 07:16 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
you should contact markski and get the car logged, just to be safe :-) 1.4 seems a little bit high, im running 1.1 and super safe tune
are you sure its 1.4 maybe its just a spike
Old Oct 17, 2014 | 07:26 PM
sparks's Avatar
only glanced at it for a second. guess it could be a spike ? I will bring to markski when he can get me in , maybe in a couple weeks. until then i'll try to take it a little easier..
Old Oct 17, 2014 | 07:31 PM
sparks's Avatar
Also, tires had 44psi in tires, brought it down to about 36psi. made quite a difference.
Old Oct 17, 2014 | 08:00 PM
it better be a spike! lol
i still get em too. spikes of 1.4 but my car can handle it as part of the tune etc and i dont "
live" there as I've said. keep an eye on it for sure.
Old Oct 18, 2014 | 12:23 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Wink
you have a leak mate probably between the coolers and the throttle body.
easiest way to fix is tighten every single hose clamp you can find and get to and then zip tie every vacuum line you can find and get too.
once done your boost be back to what it should be.
Old Oct 18, 2014 | 04:25 AM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
He may not have a leak, I have had 6 tunes with differing mods on my K24s and used to see 1.4 on several of the tunes and now I hit and hold about 1.35 bars but see as much as 1.5 on the dash, even though the datalog shows only 1.35 peak.
OP get a durametric cable and log, there is a great sticky thread here on how to do everything. It is the best $300 one can spend on a car originally costing $130,000+
Old Oct 18, 2014 | 04:35 AM
timccloud's Avatar
99.5% chance of a leak as described
Old Oct 18, 2014 | 08:37 AM
^ ya, i'm with it's a leak too
( waiting on my lamps tim..all the way from bournemouth uk..lol.. shall we synchronize our watches?? ) LOL
Old Oct 18, 2014 | 09:34 AM
timccloud's Avatar
Thumbs up
ok lets synchronize
im at sea until the end of the month so if i get mid november i very happy.
and definately a leak the op has
Old Oct 18, 2014 | 03:29 PM
sparks's Avatar
Today I took it up to 6k rpm and boost only showed 1.2 bars...I will keep an eye on it closely....
Old Oct 18, 2014 | 03:36 PM
1.2 ^ that's not an "only" number! lol.
keep watching it and sustained 1.2 maybe ok but any more? again, i'd rethink it with some diagnostic help e.g. durametric or a porsche tester.
Old Oct 18, 2014 | 04:08 PM
acmf74's Avatar
acmf74 is infamous around these parts
What is a normal max boost for a stock car?
(Non x50)
Old Oct 18, 2014 | 04:18 PM
Oh boy here we go again. Last client with the same issue gave me the opportunity and I fixed it. Ran 1 bar like it should and was day n night.
I'll do it at no charge and if it doesn't fix it you pay nothing.
Markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
