Pccb (pic) Nightmare
Old Oct 11, 2005 | 10:27 PM
calbobba996TT's Avatar
calbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the rough
about 10k miles steeet driving.
take a look
any thoghts?
Boris
Old Oct 11, 2005 | 10:31 PM
20C4S's Avatar
Boris,
what pads are u running?
Old Oct 11, 2005 | 10:34 PM
Ruiner's Avatar
Originally posted by 20C4S
Boris,
Yep, that was my first thought as well. Did you run the stockers?
Old Oct 11, 2005 | 10:35 PM
Non track version. I experience no fade and still
very confident in my braking, but the rotor feels
and looks like sand paper.
with these rotors i thought the pad would be
ruined not the rotor
Boris
Old Oct 11, 2005 | 10:58 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Wow those rotors are torn to $hit. What year is your TT (and the PCCB's)? Are they an early version or a new version? The early ones are notorious for getting destroyed by even one track day.
Old Oct 11, 2005 | 11:07 PM
the car is a 2001 first generation rotors
Boris
Old Oct 11, 2005 | 11:14 PM
oak's Avatar
oak
Porsche recommends using the green pads from PMNA if your tracking . I have a set used for sale with only 1/2 track day on the pads.
You pads probably look like this.
Old Oct 11, 2005 | 11:20 PM
I ordered cup car steel rotors and PFC 97 pads
will take a look at the pads when they get here
Boris
Old Oct 11, 2005 | 11:28 PM
Oak,
are those gt2 pccb rear caliper?
what rotor are you using are they 350mm???
thank you
Boris
Old Oct 11, 2005 | 11:35 PM
oak's Avatar
oak
Boris, yes they will fit the GT2/3 rear calipers.
I am now using steel 350mm cup rotors front and 330mm rears. Even though the rotors are different sizes in the rear the pad sizes are the same.
Old Oct 11, 2005 | 11:43 PM
Oak,
what do you think about leaving rears pccb and
steel in the front?
Boris
Old Oct 12, 2005 | 12:19 AM
oak's Avatar
oak
I know some GT3 owners that have PCCBs are running steel fronts and pccb rears and seem to be OK. Not sure about long term.
If you plan on switching to steel cup rotors for both front and rear, the rear calipers need to be changed out to the GT3 steel calipers due to the steel rear rotors are 330mm.
I believe AP or another company mfgrs a 2piece 350mm rotors as replacement rear for PCCB owners looking to switch to steel rotors will only need to switch out rotors only.
Old Oct 12, 2005 | 01:11 AM
6088TTS's Avatar
6088TTS has a spectacular aura about6088TTS has a spectacular aura about6088TTS has a spectacular aura about
i just have a question that if switching to steel rotors which pad should i be using??? by the way what wheels are those calbobba996TT???
Old Oct 12, 2005 | 03:58 AM
oak's Avatar
oak
6088TTS, you can use the same yellow P90 pads you have for the PCCB's with the steel rotors.
Old Oct 12, 2005 | 10:56 AM
the wheels are cargraphic
Boris
