Exclamation front windshield wipers quit moving, but I can hear the motor?
Old Dec 13, 2014 | 02:00 PM
BOOSTTT's Avatar
BOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to behold
Anyone know what would make my front wipers just stop? 2004 Cayenne turbo. (that forum is dead, so I'm posting here) I can move them passively with no problem. The rears to work, fuse is good, no problem with the lever, and I can hear the motor working as usual with the typical back and forth sound, but nothing moving either front wiper. Linkage? Can the motor's shaft just disconnect from the linkage? Thanks for any help. It's raining hard, so I can't take it apart to look any further at the moment. Can't plug her into my Diametric yet to look for codes, but the wiper motor sounds fine even speed changes, but no motion at the wipers. Any thoughts? My other Porsche daily driver has a busted window regulator, so I'm desperate to fix wiper issue soon.
http://www.inkilino.es/Porsche_Cayen...WIPER%20WASHER
Old Dec 13, 2014 | 02:14 PM
rmc1148's Avatar
If you hear the motor running its most likely the linkage= can you remove cover and take a look?
Old Dec 13, 2014 | 03:38 PM
Slider's Avatar
I'm pretty sure you'll see the problem if you look at the motor. Either a gear is stripped or the linkage isn't linked.
Old Dec 13, 2014 | 04:42 PM
BOOSTTT's Avatar
Finally stopped raining and I did find the drive shaft to the motor's nut was nearly falling off. It was an easy fix. I did notice the underside of my wiper blade that bolts to the linkage was nearly cracked off on one side. I tried to secure that better, but that's strange. Someone must have installed the linkage wrong in the past or something. It's working now, but need a wiper arm it looks like too.
Old Dec 13, 2014 | 07:15 PM
BLKMGK's Avatar
Rain-X will help in the meantime! Love that stuff :-)
Enemy
Nov 10, 2015 08:01 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
