Sequential Shifter? Any feedback? (sqs/m7)
Old Nov 20, 2014 | 11:41 PM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
I know of one guy who runs a sequential shifter on his high HP car.
I am looking for feedback from guys who have ran a SQS/M7 Sequential shifter?
I was pondering it for next season, just basically u preset the next gear just depress the clutch, I would think it would help make the car faster in a straight line and eliminates the chance missing a gear or just a bad shift......etc.
Old Nov 21, 2014 | 06:37 AM
'02996ttx50's Avatar
i was under the impression it is/was just an up/down shift in every gear, that you're not "pre-selecting" anything i.e. dsg or pdk. it's just a shifter, it doesn't change the way the transmission works. or does it?
ask randy he has one iirc.
Old Nov 21, 2014 | 06:48 AM
pwdrhound's Avatar
I just sold one. It does not change how the gearbox works but rather how you actuate the gears, up/down instead of an H pattern.
Old Nov 21, 2014 | 06:54 AM
thank you.
Old Nov 21, 2014 | 07:39 AM
Mit_Boost's Avatar
Mit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant future
Unless your chasing HP-limitations, not a lot of "street" cars using them -- the 9ff GTurbo, EVOMS Mayhem, BBi Kong Porsche all use sequential transmissions (IIRC, they all use Hollinger's).
Not sure if you can get the factory ECU to play nice converting to a sequential, but you're probably better off (logistically & financially) buying a modded/re-geared trans & proper short throw shifter (Numeric or CAE).
Old Nov 21, 2014 | 09:03 AM
I was under the impression it was up/down then clutch in. I guess the change isn't as good as it seems.
Old Nov 21, 2014 | 09:12 AM
Pretty sure Kong just uses a sequential shifter not transmission.
Old Nov 21, 2014 | 11:43 AM
it's gotta be a *potentially* faster shift simply owing to the new shift pattern. up/down is quicker that our H + as to whether or not it's *worth it*?
thats up you and your needs.
Old Nov 21, 2014 | 11:54 AM
If I can scoop it up used, I think I will at least try it out. Powdrhound sold his for like 2k. Thats not awful in my opinion.
Old Nov 21, 2014 | 12:29 PM
bro just pick up a numeric for 500 and be done. its gonna do the same thing. you dont NEED up/down unless youre drag racing
Old Nov 21, 2014 | 02:26 PM
That's what I'm doing. And I already have a short shifter in the car.
Old Nov 21, 2014 | 07:27 PM
32krazy!'s Avatar
drag racing is won and lost in the first 60 ft and reaction time. this shifter won't help either. if your using the clutch then the pattern doesn't matter . in road racing thats another story. (huge amounts of up and down shifting).
the only way you will get faster at this would be a "no lift shifting" file that allows you to keep your foot planted on the throttle while simultaneously engaging the clutch and shifting. hard to do as its not really natural and you have to really think about it while racing. not easy. cheaper to learn how to launch consistently and faster. if you can get 1.5 or lower 60 ft times with your power it will be hard to get beat
Old Nov 21, 2014 | 10:30 PM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
Take a look at the CAE shifter, I think that's what your looking for. 2nd to 3rd to 4th are straight push and pull because of the self center spring on the shifter. Also - the shifter is right next to the wheel.
Old Nov 22, 2014 | 06:22 AM
Puppan's Avatar
Puppan has a reputation beyond reputePuppan has a reputation beyond reputePuppan has a reputation beyond reputePuppan has a reputation beyond reputePuppan has a reputation beyond reputePuppan has a reputation beyond reputePuppan has a reputation beyond reputePuppan has a reputation beyond reputePuppan has a reputation beyond reputePuppan has a reputation beyond reputePuppan has a reputation beyond repute
I´m using the SQS latest version what do you want to know?
I use my car for roadrace and it gives me the benefit of not missing a gear both in up and downshifts.. It´s also slightly faster then a traditional H-system. You still need to use the clutch.
But a real Seq gearbox take away the possibility to use the car on the street. The Dogrings makes it jump like a rabbit if you are not going flat out and it also wears out pretty fast as its a rebuild time of the seq boxes of 30h..
/Pete
Old Nov 22, 2014 | 07:53 AM
sounds like full time racing equipment to me.
