Inlet Pipe Removal
Old Jan 11, 2015 | 12:56 PM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Originally Posted by 32krazy!
thats complete overkill if your just doing inlets. if you have to drop the motor then thats when most do it. this was the first mod i did and was determined to do it with the engine in. i succeeded but ultimately wasn't worth the hassle. should have just went mafless ripped it all out and use filter in the fender wells. much less painful in the end
He was doing a clutch change, I can pull the motor in 21/2 hours taking it easy !!!! and you can make a much nicer job with the whole lot out.
Old Jan 11, 2015 | 01:00 PM
32krazy!'s Avatar
not sure i buy 2.5 hr removal. I'm no amateur but 6 hrs was about the best i can do. again i think inlets are a hype that really don't produce much power at lower levels. at higher power levels most ditch them anyway
Old Jan 11, 2015 | 01:11 PM
In and out in a day with whatever needs doing as well ie clutch change etc, but workshop facilities help, my point is pro or amateur theres not much diff in trans or motor and trans removal. How the hell does it take 6 hours ????
Rguy
Apr 12, 2020 11:11 PM
NIKAS
Aug 20, 2019 07:53 PM
nlakind
Nov 6, 2015 10:15 AM
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
HolmaN
Aug 18, 2015 01:35 PM
