Headlight assembly problem
Old Jan 21, 2015 | 07:28 PM
khiroshima's Avatar
khiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond repute
Did a search and did not come up with a good answer, help please . . .
My entire left light assembly is out, as of yesterday. This means no headlight, running light or turn indicator on the driver's side. I originally thought I just had turn indicator light out (fast blinker), but later I discovered the whole assembly was out.
I am familiar with the headlight switch issue as I replaced one in my C2 last year, could this be the same problem? The last time I had the switch issue, both headlights were out (I don't remember if the running lights were affected), but I don't think the turn indicators were an issue. Is there a fuse that covers the whole light assembly? I don't think so, it's almost as if the whole light wasn't connected up, but losing all connections in one night seems highly improbable. TIA, KH
Old Jan 21, 2015 | 07:39 PM
rmc1148's Avatar
Take out the assembly and check with a test light, may have came slightly loose where connected to harness.
Old Jan 21, 2015 | 08:16 PM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
Originally Posted by khiroshima
Did a search and did not come up with a good answer, help please . . . My entire left light assembly is out, as of yesterday. This means no headlight, running light or turn indicator on the driver's side. I originally thought I just had turn indicator light out (fast blinker), but later I discovered the whole assembly was out. I am familiar with the headlight switch issue as I replaced one in my C2 last year, could this be the same problem? The last time I had the switch issue, both headlights were out (I don't remember if the running lights were affected), but I don't think the turn indicators were an issue. Is there a fuse that covers the whole light assembly? I don't think so, it's almost as if the whole light wasn't connected up, but losing all connections in one night seems highly improbable. TIA, KH
I had similar problem on my C4S. The latching mechanism wasn't fully engaged. This was because the hokey wrench thingy was sort of stripped. I used a little metric socket on a long extension and that fully seated the light assembly into the socket.
Old Jan 21, 2015 | 09:19 PM
khiroshima's Avatar
Thank you, Gents
Sometimes I hate it when I'm so dumb . . . Not realizing that the whole assembly is connected with a single Molex connector, the fact that the light wasn't seated properly makes 100% sense. I (foolishly) thought that each light had its own wire assembly, as I have never taken the headlight out before.
I appreciate the help and I went to YouTube to watch how easy it is to R&R a headlight. Love this place, KH
EMC2
Cayenne 955/957
Sep 7, 2015 05:20 PM
ECS Tuning - VW
Aug 28, 2015 11:10 AM
LiquidElephant
Aug 27, 2015 06:17 PM
