Can the Sachs 764PP be modified for more clamping force?
Old Feb 2, 2015 | 06:11 PM
pwdrhound's Avatar
Just like the title says, can the Sachs 764PP be modified for more clamping force? Has anyone done it and what would the limits be? I'm looking at holding about 650whp and torque. The stock 764 may be fine but looking at options in case it's not. I would like to stick with the 4.0 disc I'm running due to it's excellent drivability. No, I don't wanna go to ERP, Tilton, or any other multi plate clutches unless absolutely no other option.
Old Feb 2, 2015 | 06:25 PM
32krazy!'s Avatar
just so you have at one other option or opinion, once my carbonetics triple c/f clutch was broken in (1000 miles) its fantastic in traffic on the drag strip or cruising down the road. a bit noisy at the light with the pedal depressed but not jerky notchy or uncooperative. works better than my oem clutch ever did. even the smallest p/p (1100kg) will hold the power your wanting to be at
Old Feb 2, 2015 | 06:46 PM
pwdrhound's Avatar
Thanks for the input. The problem is the fact that it's such a crap shoot when it comes to the multi disc clutches. Everyone seems to have a different experience and I don't care to be another Guinea pig. I've driven numerous cars with ERPs and Tiltons and have yet to drive one that I would find acceptable (for me). I'm sure they're good clutches for 900, 1000, or more hp but I just don't car for their engagement point, feel, etc. None even come close when compared to the feel and modulation of a GT2 764/4.0/964LWFW set up that I currently have. Hence my question to possibly increasing the clamping force of the 764 set up. That would stiffen the pedal a bit but keep the feel the same.
Old Feb 2, 2015 | 08:57 PM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
No, I don't think it can be. I sent mine to clutch master brand new, and they sent it back saying they couldn't do anything.
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
Is it slipping already or are you just being proactive? This clutch is at the top of my list due to your and others' recommendations but I'm planning to eventually go with A28s and would like to make sure this has sufficient holding power.
Old Feb 2, 2015 | 09:54 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
think Southbend modifies Sachs P.P. as part of their packages, maybe ask them if their clamp is better then the 764
Old Feb 2, 2015 | 10:47 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Interesting thread.. This is a great question.
I hate my ERP triple clutch during stop and go traffic. Engagement point is to short for me. I understand the "slipping clutch theory" but, at the track, the clutch performs very well. You may want to drive my car for a few more laps "alone" at the track to get a good feeling for it.
Forget the engagement point that I complain about as, most have modified the master cylinder pin to change the height of engagement.
You could also borrow it for a weekend if that helps with your decision.
Let me know,
Old Feb 3, 2015 | 12:56 AM
pwdrhound's Avatar
No, it's not slipping at all and feels perfect. The 764PP/4.0/964RS LWFW is hands down the best clutch I've ever had, bar none. I'm not putting out huge power as I'm at 590whp/630ft.lb but my engine is getting rebuilt right now and will probibly be a bit stronger at closer to 650whp. I'm thinking I'll still be fine as it's a road course set up and not a 1/4 mile car but I'm just looking at options as everything is out right now. If it's a problem than I'll address it when the time comes I guess but just looking at my options.
Old Feb 3, 2015 | 01:02 AM
pwdrhound's Avatar
Let me know,
It's an option. I wonder if the twin plate set up has better feel? Also curious if the high engagement point in your case is a function of the evoms bracket. I suspect if you go with the drill and tap method the engament may be better as it changes the angle of the slave rod. Probably doesnt take much. The engagement might be better on my car since it has the factory GT2 set up. Hopefully I won't have any issues with the clutch but we'll see. I emailed Kevin at UMW and he says he has an option for modifying the 764 for more clamping force but it's a 2-3 week wait which in this business generally means 4-6 as I've learned. Kevin's option includes a higher friction disc which he said will make the clutch more grabby. His stuff is top notch and certainly might be a solution if one needs something more than the 764. I guess I'll deal with it when I cross that bridge..
Old Feb 3, 2015 | 01:12 AM
elite1's Avatar
Originally Posted by pwdrhound
It's an option. I wonder if the twin plate set up has better feel? Also curious if the high engagement point in your case is a function of the evoms bracket. I suspect if you go with the drill and tap method the engament may be better as it changes the angle of the slave rod. Probably doesnt take much. The engagement might be better on my car since it has the factory GT2 set up. Hopefully I won't have any issues with the clutch but we'll see. I emailed Kevin at UMW and he says he has an option for modifying the 764 for more clamping force but it's a 2-3 week wait which in this business generally means 4-6 as I've learned. I guess I'll deal with it when I cross that bridge..
Drive my car dude.
I agree, the wait is ridiculous in this industry. Like I stated from time to time, "We live in a Microwave world." we need results yesterday.
I would love to hear your opinion on my setup. Mine opinion is based off a weak stock setup and an extreme ERP 3X setup.
You have experienced the mid point with your current setup.
My car sucks in first but, its nice once moving.
Old Feb 3, 2015 | 01:25 AM
pwdrhound's Avatar
Drive my car dude.
I'll need to drive it again. I drove a session with it at the track but it's been a while. I like to have my cake and eat it too. Maybe this weekend if the snow melts...
Old Feb 3, 2015 | 01:30 AM
elite1's Avatar
I'll need to drive it again. I drove a session with it at the track but it's been a while. Maybe this weekend if the snow melts...
66 on Friday, should be good for some street driving.
Old Feb 3, 2015 | 01:41 AM
pwdrhound's Avatar
Gonna run by the shop Friday. Do lunch?
Old Feb 3, 2015 | 01:44 AM
pwdrhound's Avatar
Why couldn't tell you over the phone that is was not possible thus saving you the hassle of sending it in? It's not like they've never seen a 764PP before. At least you would think..
Old Feb 3, 2015 | 01:57 AM
elite1's Avatar
Sure dude, I don't drive my 911 to work but (I work on Friday's,) you can pick it up in the morning though.
I'm almost always up for lunch.
