Another coolant line failure...
So, how do they access them motor in? I always thought that wasn't possible? I would certainly bump this project up in priority if that's true! Any idea on cost of getting this done motor in?
First, happy new year everyone. I got a little carried away in my post above. Cup teams do weld the fitting but nearly all GT3 street cars get the fittings pinned. Why? to prevent them from coming out and dumping all your coolant. And also to enter track events. Now Sharkworks drops the motors AND he still pins the fittings. I had a fitting blow out on my car and thats why I pinned EVERY fitting to prevent this from happening again. I do not want to be on boost going to Las Vegas and having this happen. It is a preventative procedure that everyone should do. That all I am saying.
To knurl every fitting on your cars means dropping the motor and heating up every fitting and regluing. If your going to do this then WELD. So knurling is out unless you have a fitting already removed.....does that make sense?? Do all eight boys,,,,its pretty simple, Mike
Thanks in advance.
