Tiptronic
Old Feb 8, 2015 | 10:52 AM
Bader996's Avatar
Bader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud of
Tiptronic
Hi all
I have a problem that I would like to share, maybe someone can help
Have 2001 TT tiptronic , on Rpm 5000 and up , shifting manually is totally fine . Automatic ( it lags from 3rd to 4th and changes to 5th quickly ) . Tried lot of things and no go. My mechanic swears it's the volvebody !
Any suggestions specially it shift normal on manual mod
Regards
Old Feb 8, 2015 | 08:42 PM
Bader996's Avatar
Went to the garage today and waiting on him to change the valve body switches
Old Feb 15, 2015 | 10:33 AM
Bader996's Avatar
Changed the valve body , still doing the same thing 😏
Old Feb 15, 2015 | 11:01 AM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
my bet is you've worn down k3 clutch pack
Old Feb 15, 2015 | 11:12 AM
Bader996's Avatar
I replaced them 3 months ago
Old Feb 21, 2015 | 06:54 AM
Sveina's Avatar
Sveina is infamous around these parts
How is your ATF change history?
Old Feb 21, 2015 | 08:16 AM
Bader996's Avatar
Honestly not that good , last time 3 to 4 months ago when I replaced the tiptronic clutches / mechanic said he did change it . Would an oil change affect it ? And I appreciate you for replying
Old Feb 22, 2015 | 08:28 AM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Some info
Old Feb 22, 2015 | 09:01 AM
Bader996's Avatar
Hey pat , I saw that , I changed the body volve , still not shifting on 5000 rpm from 3 rd to 5 th as good
Old Feb 22, 2015 | 09:02 AM
Bader996's Avatar
How is your car doing ? Did you get it fixed ?
Old Feb 22, 2015 | 10:00 AM
pat's Avatar
pat
Could be a shaft pressure seal. The seals along the shaft keep the fluid going to the right clutch pack. If the pump is not pumping as it should and if one of those seals are not sealing right or is basically worn the right amount of pressure will not go to the clutch pack. That looks to be what happened to mine. The smallest seal twards the tip of the shaft went partially bad. It doesn't take much deviation from how it is supposed to be and things no work right.
Old Feb 22, 2015 | 10:09 AM
Bader996's Avatar
I will check mine and update
Old Feb 22, 2015 | 02:05 PM
Sveina's Avatar
Mercedes had that problem with some of the produced transmissions in 2000. They altered the seals within that year. This was for the 722.6 transmission which has pretty much the same internals as the tiptronic on 996. (Not the same external house).
ATF change is the key to a long life on these trannies. MB operates with changes at 38.000 miles or sooner if driven hard.
Old Feb 22, 2015 | 05:00 PM
one way bearing when in auto mode can be the issue... which explains one in manual mode it does not act up
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 1, 2015 | 10:57 PM
Bader996's Avatar
Now Iam having the following
P0701 Porsche fault code 554
Tiptronic transmission g100 fault code 13 rpm sensor n3
50
Impermissible transmission ratio
39
Can: dme communication disturbe
9110
Dme control unit
That's all 😏
Anyone know anything about these codes , it's very frustrating
