What else to change while engine/trans is out??
Old Mar 9, 2015 | 02:53 PM
TighTT's Avatar
TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !
I'm prepping for the install of my new Sachs 2.5 clutch. Im sticking with the OEM flywheel (hopefully its in good shape). While the engine is out...what should I replace? Anything in particular? I plan to change out different vacuum lines etc.
Old Mar 9, 2015 | 04:04 PM
'02996ttx50's Avatar
rms if nothing else.
Old Mar 9, 2015 | 04:09 PM
rmc1148's Avatar
Water pump if older and all hoses if original, have you pinned/welded fittings? You will get a lot of suggestion's. Kick butt list of cars love the Audis.
Old Mar 9, 2015 | 04:49 PM
BLKMGK's Avatar
Why is the engine being pulled to swap a clutch? If you search this question has been asked at least 2x in the last 2 months or so with a heyuge list of suggestions to choose from that will have your wallet hurting if you aren't picky
Old Mar 9, 2015 | 05:18 PM
yeah thats a good point. its just the trans you're pulling out of the way to get at the clutch. the engine is staying lol. if every things working? and the oem dmfw looks ok? change out the clutch and the rms and button it up!
Old Mar 9, 2015 | 05:47 PM
602996TT's Avatar
602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future602996TT has a brilliant future
https://www.6speedonline.com/forums/...uild-time.html here is my thread of what I replaced good luck I'm about do all over again for the 2nd time this year.
Old Mar 10, 2015 | 12:51 PM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
Here is some ideas:
Coolant tank
Coolant flush
All coolant hoses
Weld the coolant pipes - you are 2/3 of the way there as the engine it out
fuel filter
water pump
engine mounts
transmission mounts
drive belt
Old Mar 10, 2015 | 12:57 PM
LuvPorsche's Avatar
LuvPorsche is infamous around these parts
get rid of pancaked piping with new piping
coils+ plugs
check tb/plenum + all hoses
check axles
look over bushings
get a rear locking toe link set up
Old Mar 10, 2015 | 01:49 PM
mdurbahn's Avatar
mdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud of
I would do inlet tubes too.
Old Mar 10, 2015 | 05:23 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
My car has been in the shop for some upgrades, fixes, and preventative maintenance. Here is the list in no particular order:
Coolant pipe fix
Expansion tank
Water pump
Check valves (I thought there was only one, but there are two)
Oil pressure sending unit
Metal turbo oil feed lines checked
Waste gate vacuum lines
5 bar fuel pressure regulator
Clutch kit
Slave cylinder (found it was leaking a bit with the engine removal. Bad news/good news)
Pressure accumulator
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Endless brake fluid
Coolant
Throttle body seal
Precision Porsche GT2 deck lid (wing painted matte black)
GT2 deck lid wiring harness
Transponder
Coil packs
Solenoid brackets
Engine mounts (RSS)
Trans mount (997 version)
Multi-rib belt
2nd gear detent
So after all this, no more thoughts about blowing a coolant fitting at the track.
Old Mar 11, 2015 | 01:34 AM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Ipd plenum
Old Mar 11, 2015 | 06:47 AM
eds966tt's Avatar
eds966tt is infamous around these parts
curious are you doing the Sachs 2.5 clutch or what shop are you using in NJ?
adnanm3
Nov 22, 2023 02:43 AM
Rguy
Apr 12, 2020 11:11 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
