SShrum build...
Build continuation: forge hoses (top) and new OEM motor mounts, decats on turbo, 911tuning intake hose/Torque toes/Eibach sway bar install, barrel of the gun, different angle
Double check now that your decat flange diameter matches the alpha turbos. You don't want a lip shrouding the wastegate exit. Will create boost issues. It's much easier now to check, and port the decats to match, then to do it later.
Thx for the tip.
Great build by the way. Glad Sam has your back, can't go wrong.
Untuned Kline 70mm stainless exhaust sound (in neutral, engine lid open...lots of engine noise, sry)...I'll post more later with lid closed and I'll strap a gopro back there during a run once we get a tune in.
