997GT2 transaxle
997GT2 transaxle
Trying to judge current market, might be looking for one...What is a good used 997GT2 gearbox worth? Availability?
My Dad is buying a 996TT, tiptronic we plan on converting to manual, considering using my 6GT2 box in that and getting a 7GT2 box for mine.
TIA
-Rob
TIA
-Rob
+1 mainshaft, the slightly longer gearing is the main advantage to me, however the stock 997 LSD's are junk
I view it as killing 2 birds with one stone, give a TT a better trans with good LSD and I get a longer gearset trans for my GT2..also 'forces' me to install a streetable clutch in mine since I have it apart...
of course it need to make some sense financially...
Then you can do all custom gear ratios and what not and it will be less then a oem 996 GT2 gear box i would venture to guess.
not against that idea, but still need a manual box for dad's TT...he doesn't need anything special (but LSD is real nice to have) so my gearbox would be a good retrofit for his car...
neither of us want big power(<600whp), so a 7GT2 box with Guard LSD ramps and plates would be perfect for me
purchase right was RIGHT! and add to that it's hard to find a decent 996TT here in Canada, regardless of price. Hot market here(I've been hunting for friends too).. Current exchange rate (= duty,tax etc.)= +40%, makes American cars undesirable
stock 6spd TT's have a poor shifter, poor clutch, no LSD.... Tiptronic TT's already have a GT2 P.S. pump...
The work is easy for me, it's all about the numbers.
Guard/GT Gears said the last 7GT2 trans known sold at $18k...even if we installed that box, the car's cost would still be $ par or below a similar 6spd TT here
won't be the route we go, but considering other options to hopefully get similar effects for less $...
Might contact Raider and Copans to investigate further
Thanks!
Thanks!
use a 996 tt trans build it with 997t2 parts (4500$ or so plus labor) add powder hounds diy cooler setup and a wavetrac (1200$ plus labor) and your set. this will hold close to 1000 hp and half the cost of a gt2 trans. drop yours in your dads car
another idea present by Guard was using a 6GT3 box as-is (refresh LSD)
...an idea I spawned off that was, find a tired GT3 box and re-do the internals the way I want and use that box in my car and put my GT2 box in dad's TT..
or, just find a TT box and install a LSD in it and call it a day for the TT...
off the top of my head you need clutch and brake pedal box, trans, clutch,flywheel, cables, shifter, console, neutral safety switch, slave setup, master cylinder , reservoir, power steering pump and reservoir(if your not using the gt2 setup) petosin lines from the reservoir. the trans will seem cheap after pricing all this!
