Stock making 1.3 bar and higher.
Old May 2, 2015 | 08:00 AM
PatrickBE's Avatar
PatrickBE is infamous around these parts
Hi guys,
after changing the spark plugs,
replacing the clamps on the intercoolers & turbo hoses
and cleaning the MAF
the car makes 1.3 to 1.5 bar when i make a full throttle run (any gear).
Just to be 0.8 - 0.9 bar.
I have no idea what's wrong (if anything is wrong) any suggestions on this?
No durametric so no fault codes available.
Also looking for the correct ref. to this coolant hose on the passenger side
(which bursted during the test runs)
after my search in PET i'm not sure it's the correct one.
Thanks in advance,
Patrick.
Old May 2, 2015 | 08:14 AM
raineycd's Avatar
Check to be sure the vac lines are on the turbo wastegates secure. Did you do any work on top? If so, check N75 connections, etc.
Old May 2, 2015 | 10:04 AM
Vendetta's Avatar
Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !
...also, you're sure it's stock?
-V
EDIT: OP, I also just noticed your avatar - the Porsche Design hot water kettle! LOL I had one of those 10 years ago! The toaster, too.
Old May 2, 2015 | 10:10 AM
'02996ttx50's Avatar
+2 on wg's. check for proper adjustment.
Old May 2, 2015 | 11:39 AM
PatrickBE's Avatar
Thx for the help guys, appreciate it! i'll check the wastegates and the N75.
(didn't do any work on top)
I'm the 4th owner so i'm not absolute sure, the previous owner told me it was stock...
Old May 2, 2015 | 11:51 AM
Vendetta's Avatar
I'm gonna guess it's tuned.
Easy to tell, too. Any local dealership or someone with a Durametric can read your DME to tell you if there are any "programming events" in there. If >1, then there was a post-factory tune put in.
Good luck and keep us posted.
-V
Old May 2, 2015 | 03:49 PM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
Check for boost leak, if it used to make .8-.9 and now 1.3 it looks like the wastegates are not working, maybe a hose come loose while doing the plugs.
Old May 3, 2015 | 12:38 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Thumbs up
boost leak for sure
Old May 3, 2015 | 01:21 AM
PatrickBE's Avatar
Okay boost leak test it is. I'll do some research for a DIY about this.
@timccloud LOVE the 4S lip !
Old May 3, 2015 | 02:03 AM
PatrickBE's Avatar
I'm confused
Boost leak test at the turbo inlets or testing after the MAF ?
Our those 2 different tests
Do i need to do both test to be sure?
Yep i'm a turbo noob.
Old May 3, 2015 | 02:39 AM
timccloud's Avatar
before u test tighten every clamp you can see and zip tie every vacuum line u can find then test and tighten the rest where they leak
Old May 3, 2015 | 07:10 AM
always test from the turbo inlets. it;s rare that doesnt reveal the cause of any leak(s). waste gates being out of whack or bad n75 or even the notorious check valves along the intake system going bad are also probable and likely sources of your issue(s) if the boost leak testing doesn't instantly reveal a leak.
but "it" will help you locate those, but it won't tell you whether the n75 is bad or if the wg's are not opening equally and to their proper settings.
Old May 3, 2015 | 10:20 AM
PatrickBE's Avatar
That's why i love forums ! THANKS guys !
Jul 29, 2019 11:13 AM
