k16 billets run 11.1 sec @126 mph
Old May 29, 2015 | 02:19 PM
been working with a client in the land down under, helped him with boost leaks and maf issues, IPD plenum didn't have a check valve, made him throw in some injectors vs. a 5 bar and retuned it...It is a TIP, on R888 tires AWD and ran 11.1 with a bad high 1.7 60 ft. I know he will get into the 10s very soon...
It took me some work but he went from running 122 mph to 126 mph and gained .3 seconds in a 1/4.
For more info on our 996TT porsche tuning options please click here
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 29, 2015 | 02:34 PM
mtlsp's Avatar
mtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond repute
solid number for k16 billet ! how much boost?
Point2Point's Avatar
Point2Point is a splendid one to beholdPoint2Point is a splendid one to beholdPoint2Point is a splendid one to beholdPoint2Point is a splendid one to beholdPoint2Point is a splendid one to beholdPoint2Point is a splendid one to beholdPoint2Point is a splendid one to behold
What exhaust?
RxPorsche's Avatar
RxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud of
Thumbs up
Really impressive; that's Markski magic in action!
Old May 29, 2015 | 03:01 PM
I think 10.8 is doable with more boost and better traction. He's at 1.4 bar peak. He has some 200 cell exhaust not sure which one. Not sure about Intercoolers but has something cheaper if I recall correctly.
9.66
click to view
Old May 29, 2015 | 03:15 PM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
Off the Facebook post:
Porsche 996 TT TIP Upgrades:
Bigger headers (1 & 3/4 qtr)
Custom 3inch X design exhaust system with 100-Cell sport cats
K16/68 Billet Hybrid Turbos with 1bar Tial WGs
Forge intercoolers/piping
Forge diverter valves/f pipe
60lb Siemens fuel injectors
Denso double platinum spark plugs
Evoms IPD 68mm plenum
Evoms Hitachi air induction
Custom tunes to suit with 1.3-1.4bar commanded in the ecu
Toyo R888 Semi slicks.
105octane fuel
Old May 29, 2015 | 05:25 PM
Bader996's Avatar
Bader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud of
Good job marek , congrats tithe owner
Old May 29, 2015 | 06:48 PM
'02996ttx50's Avatar
interesting to me the use of the smaller ipd 68mm plenum.
Old May 29, 2015 | 07:34 PM
I believe he bought the car with many of the parts on it already. I just added injectors, made him pressure test, fix the leaks and changed the Maf. Then I just tuned via data logs.
We can push it to 1.55 bar as long as he hooks.
9.66
click to view
Old May 29, 2015 | 09:20 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Nice
Old May 31, 2015 | 06:00 AM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
What flow rates on the K16/68mm ?
Old May 31, 2015 | 01:43 PM
Ringlord's Avatar
Ringlord is just really niceRinglord is just really niceRinglord is just really niceRinglord is just really niceRinglord is just really nice
Does the boost curve on these need to be toned down for the rod's sake, or are these turbos safe to push all out on a stock motor?
I'm really curious as to what these can do on a stock motor running pump gas.
Old May 31, 2015 | 02:06 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
On stock ECU with injectors, it seems like 1.4bar is max on pump(93) gas.
Even though it hits hard, I don't think you're going to bend any rods.
On race gas? I still think you'll be ok.
Old May 31, 2015 | 08:20 PM
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
Awesome!
Old Jun 1, 2015 | 09:29 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Very nice. Tips are great drag cars. Consistent for a few pulls until that tranny gets hot.
