p2135 p0121 p1266no throttle
Old May 29, 2015 | 05:44 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
function monitoring fuel shutoff p1266
accel pedal potentiometer p2135
accel pedal potentiometer p0121
i've lost all throttle input 3 times today. once at a light. twice left lane busy traffic high speed on highway...that was scary trying to coast to far right
Shutting off engine and restarting everythings back to normal but all of a sudden, no throttle input at all...throttle pedal absolute no response...
durametic codes listed above...anyone have any suggestions?
Old May 30, 2015 | 06:28 AM
mtlsp's Avatar
mtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond repute
look like the pedal sensor or wiring issue
good luck
Name:	Capture d’écran (86).png
ID:	421228   Click image for larger version
Name:	Capture d’écran (88).png
Old May 31, 2015 | 08:54 AM
BLKMGK's Avatar
Sounds like an issue with the throttle pedal based on the codes above, check the wiring at the pedal to see if maybe it got knocked loose? Pedal would be my next guess but it's only a guess and you probably want to be more sure before swapping $$ parts.
Old Dec 11, 2016 | 07:12 PM
gclasse's Avatar
gclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond repute
Just got these codes today!, geetee can you share if you resolved this?.
Old Dec 12, 2016 | 06:20 PM
geetee's Avatar
I have a sprint booster. Inside SB solder came loose/contact intermittent cause loss of throttle. Sent it back and got a new one.
Old Jan 25, 2017 | 10:00 AM
gclasse's Avatar
I have already replace the Pedal Sensor with a brand new unit, still having the issue. but now codes are P2135 and P0122,
Could this be related to the TB?? which ground point(s) should i check??
Old Jan 26, 2017 | 08:19 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
This happened to others and you need to clean the throttle body with throttle body cleaner. I had this happened with a throttle jacking code that came up.
Old Sep 15, 2022 | 05:02 PM
Depswatooth's Avatar
Depswatooth is infamous around these parts
Here are the codes Im getting. I thought it was a boost leak at first, but then I got the go to Workshop Check Engine light. P2135 Throttle/Pedal Position Sensor/Switch A / B Voltage Correlation
P0121 Throttle Position Sensor (TPS) “A” Circuit Range Performance Problem
P1508 Torque comparison function monitor.
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
007 Vantage
Oct 8, 2015 08:35 PM
