Slightly different way of doing a 2 pump system
Old Jun 11, 2015 | 08:12 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
This method could be my 'plan B' if I have any fueling issues. I'm hoping NOT. Keep us posted on how it works out.
Old Jun 11, 2015 | 09:34 AM
i have thought about this many times. my concern always was drawing too much electricity. 2 pumps in the saddles that are always running and 2 more in the basket feeding the rails, ok one is staged but still 3 pumps running all the time. that's 3 potential failure points.
as far as your jet pumps no feeding back up that should be very easy to diagnose as to why that is happening....
#TeamAIM
Old Jun 11, 2015 | 10:53 AM
03EvoIII's Avatar
Actually I didn't think he was running the pumps in the swirl pot...he took them out and just tied them on the jet pump arms in each side's sump (I think that's it?). Sounds like he's only running 2 FPs altogether. That would be A LOT of pumps in the tank though! lol
Old Jun 11, 2015 | 01:56 PM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Correct, ive moved the 2 walboro pumps to the saddles and I have the SRM kit with uprated loom and 2 relays. So 2 pumps total same as would be in the swirlpot.
Old Jun 28, 2015 | 05:23 AM
Having just had to change the fuel pump wiring on a dual 044 setup to 30amp I decided to take my system apart and do the same so I thought I would grab you guys some pics.
Old Jun 28, 2015 | 05:27 AM
I have disconnected the venturi hoses from the jet pumps (one remains as the convoluted, the other I changed to a fuel hose) and drop the return into the black fitting that T's into them so that the fuel returns direct to each fuel pump.
Old Jun 28, 2015 | 03:50 PM
03EvoIII's Avatar
Looks good and should work great! Why not just dump the jet pump to save some space and use the arm alone though? If i would have done it this way I could have easily run dual 450lph walbros instead of dual 340lph pumps in the swirl pot. When i get some time i'll start looking at fabbing something up to do this method. I'd rather do this method than sumping the tank and running external pump/s. good luck and keep us posted.
Old Jun 29, 2015 | 02:26 AM
Not being sure how it would work I wanted it to be somewhat reversible if needed. If there was a way of filling the big black tube with a product resistant to fuel that goes solid then that would make them even sturdier.
orbelo
Aug 30, 2015 12:26 PM
LiquidElephant
Aug 27, 2015 06:17 PM
ECS Tuning - VW
Aug 27, 2015 08:30 AM
Zero911
Aug 24, 2015 06:51 PM
