Does this sound like a Rod gone ?
Old Jun 11, 2015 | 06:44 PM
  #31
BLKMGK's Avatar
You're doing pretty much exactly what's on my future wish list for safety. If possible a light port on the heads would be worthwhile but the snowball will only grow if you start thinking along those lines :-O
Old Jun 11, 2015 | 06:58 PM
  #32
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Originally Posted by wolfhedge
I was getting a weird rumble/grumble in 3rd-4th gear on WOT at max torque levels (4000-4400 rpm) just as max boost was reached on and off for a few weeks.. could this be indicative too of IMS failure (ball bearings rattling at high speed ?)
No what u are describing here is most likely detonation.If it were valve train related or ims related u would hear it in every gear.U are under full load and able to build peak boost in those gears which is why it makes me think detonation.Maybe u got some bad fuel.
Old Jun 11, 2015 | 07:39 PM
  #33
32krazy!'s Avatar
tim will want carrillo rods, racewear headstuds, 997 lifters, oem head gaskets and a gt3 oil pump. he will massage the heads, oring the cylinders and insect the liners and pistons for wear and clearance the oil pump. this will get you into 4 digit hp with proper fueling, turbos and tuning. once this is all done you will have to address the transmission axles and clutch
Old Jun 12, 2015 | 06:43 AM
  #34
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
Not going for 1000 whp as I am RWD and slowly going up the power leaderboard... probably just do the basic engine build to start with and other turbos
Old Jun 12, 2015 | 07:40 AM
  #35
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
Wolf keep us updated. If you towing the car to the shop, true, no reason to start the car. or even look for clues..let them do the work good luck mate
Old Jun 12, 2015 | 07:55 AM
  #36
wolfhedge's Avatar
Yeah I have not started her since the other night.
Had my local guy here who listened to the videos..... he says it could also be as simple as the water pump gone as it makes a similar sound when busto... it is a common problem here on the 996TT he says and I was fiddling about there the other day and had just topped up coolant the day before this all happened but I do not want to start it to check as it will be pulled apart anyway
going through some very recent datalogs it does show a higher than normal coolant temp but not dangerous... i did not log the other night though
we shall see
Old Jun 12, 2015 | 08:26 PM
  #37
32krazy!'s Avatar
that IS basic engine build! same setup from 700 to 1000 hp. its the fueling and turbos, tuning that make the difference. from inside the motor its all the same when upgrading
Old Jan 1, 2018 | 08:09 PM
  #38
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
I'm resurrecting this thread for the benefit of others with the similar issues as the OP did not post an update. Last month I had the exact same noise as in the video in post #9. I was fearing the worst, but it did turn out to be a bad water pump. Still a $1600 fix with parts and labor...!
we shall see
Old Jan 2, 2018 | 09:27 AM
  #39
'02996ttx50's Avatar
glad to hear ya dodged an expensive bullet!
but geez, all them fancy parts ya got from sam, and the only thing ya could break was a water pump?! lol
btw happy gnu yr bo!
Old Jan 2, 2018 | 10:17 AM
  #40
SamboTT@ByDesign's Avatar
Cheers to that!
Old Jan 2, 2018 | 11:08 AM
  #41
lol, and a happy GNU year to you too sam!
Old Jan 4, 2018 | 08:16 PM
  #42
ASLAN's Avatar
Thanks Mark! Yep, car is Sambostrong!
Old Jan 4, 2018 | 08:58 PM
  #43
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Wow, 250 dollar pump. You got hosed on labor, 3 hour job max.
Hybrid
Jun 28, 2024 06:05 AM
Feelgood MD
Mar 24, 2016 09:35 AM
Texas1
Sep 20, 2015 09:12 AM
jyupitt1
Sep 10, 2015 08:31 PM
