For those who replaced the voltage regulator
Old Jun 22, 2015 | 08:38 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Car was dead today after 2 days. The battery was 2 months old. There isn't a drop left in it. I think I fried it. Is there a possibility the ecu is done????
Old Jun 22, 2015 | 10:00 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
get the car scanned. I'd also throw a new ignition switch in it before anything
Old Jun 22, 2015 | 11:07 PM
BLKMGK's Avatar
You said it got hot when the battery was overcharging right? I'd expect that to damage the battery.mhowever there's also been cases of a regulator drawing the battery down. If you can get a good battery in there and measure current draw you'll have a better idea as to what's going on IMO.
Old Jun 22, 2015 | 11:29 PM
VGLNTE1's Avatar
Why an ignition switch?
Scanned at a dealer?
Old Jun 22, 2015 | 11:30 PM
VGLNTE1's Avatar
Ya..it was hot and I saw fluid pumping out of the overflow tube. I ordered a voltage regulator and pulled the alternator tonight. Be here in a couple days
Old Jun 23, 2015 | 07:25 AM
993GT's Avatar
ignition switches can cause a myriad of issues, and on-top of that are a common failure point in these cars...good maintenance item that might also solve some of your issues.
Durametric to start and dealer if no results..
Old Jun 23, 2015 | 07:26 AM
993GT's Avatar
+1, and I wonder if the alternator is stuck on...
Old Jun 23, 2015 | 08:13 AM
VGLNTE1's Avatar
I don't have a diametric. Is there an link anywhere to the one I would need?
Old Jun 23, 2015 | 08:49 AM
rmc1148's Avatar
Old Jun 23, 2015 | 09:09 AM
VGLNTE1's Avatar
Originally Posted by rmc1148
Ah. Never knew it was just a cable. Thought it was a scanner.
Will just the enthusiast kit work and use it with my pc?
Old Jun 23, 2015 | 09:16 AM
rmc1148's Avatar
Yes and they offer reconditioned for less if you call= usually/sometimes. Have you put the regulator in?
Old Jun 23, 2015 | 09:40 AM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
Despite this I would not replace the ignition switch at this point. Get the charging system fixed and go from there. If the ignition switch caused absolutely no probs before the alternator issues, it is one of the items that will def not be affected by overcharging.
Sorry, but I like to know exactly what caused a problem and what fixed it. Throwing parts and money at a car is a common repair tactic (even at dealers) that makes me sick.
If you want to replace the switch as a maintenance item, do it once the car is back up and running.
Old Jun 23, 2015 | 10:19 AM
VGLNTE1's Avatar
Not yet. Pelican parts is not the fastest shippers. After 3 days it's still in California
Old Jun 23, 2015 | 10:20 AM
VGLNTE1's Avatar
Ya, I've never had any of the ignition issues.
Old Jun 23, 2015 | 10:41 AM
rmc1148's Avatar
No big deal if no hurry, probably could have gotten locally faster. Amazon is a good place to look and usually fast for me as is ECS Tuning.
