For those who replaced the voltage regulator
Old Jun 20, 2015 | 10:00 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
What was your symptoms? High or low voltage?
Old Jun 20, 2015 | 10:36 AM
rmc1148's Avatar
Usually shows low but can be high, need to have it checked. You can check your self with multi meter. I would not keep running car as it can cause real damage.
Old Jun 20, 2015 | 10:52 AM
VGLNTE1's Avatar
I got the car home, and then it wouldn't start. Smelled very gassy. I read somewhere this could fry coil packs.
How can I rest the regulator? Doesn't the alternator need to be removed to even get to it?
Old Jun 20, 2015 | 11:08 AM
rmc1148's Avatar
Yes needs to be removed and yes over charging can cook a lot of things but surprised it didn't burn out line fuse, if our cars have one? There is diy here or rennlist for regulator replacement, not hard.
Old Jun 20, 2015 | 11:25 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
I've had regulators fail with both high/overcharging and low voltage scenarios, but mostly low voltage/low charging
Old Jun 20, 2015 | 11:44 AM
VGLNTE1's Avatar
Does it cause a limp mode? My car will not make any boost. .2 at Max
Old Jun 20, 2015 | 02:22 PM
993GT's Avatar
It could in theory if the over-voltage has fried one of many components...can you test your N75 valve?
Old Jun 20, 2015 | 02:25 PM
VGLNTE1's Avatar
No idea how to test that...
Old Jun 20, 2015 | 02:29 PM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
For me there was low voltage, only 12V on the dash gauge which raised the red flag, them then a light came on saying generator or something, then finally the battery light.
I wasn't far from home when this happened so I tried to make it back.
Car got down the 10.5 and all sorts of lights came on, psm abs, check engine, etcs
Old Jun 20, 2015 | 04:36 PM
993GT's Avatar
Better yet, do you have a Durametric? run a short test...
Test n75 by applying voltage and seeing if valve cycles
Old Jun 20, 2015 | 05:43 PM
VGLNTE1's Avatar
I sure don't. It's something I need to get someday. Staying stock I never saw the cost benefit
Old Jun 20, 2015 | 07:12 PM
deckman's Avatar
It's been a long while. I recall I removed the alternator and took it to an auto parts store and had it bench tested. It passed, but clearly wasn't working. I heard somewhere else that it would likely be the voltage regulator in this situation. I replaced it, crossed my fingers and installed it.
Old Jun 22, 2015 | 09:31 AM
VGLNTE1's Avatar
I was always under the impression the n75 was a vacuum controlled valve. Like a pcv. Never knew it was electric
Old Jun 22, 2015 | 09:58 AM
993GT's Avatar
3-way airflow valve(high pressure, vacuum, wastegate flow) controlled by electric cycling
allows air to be directed to wastegates to reduce/control boost, the vacuum line/relief allows pressure to be relieved from the wastegate pressure line to increase boost/cycle pressure out, high pressure side is the feed/signal.
Old Jun 22, 2015 | 10:18 AM
rmc1148's Avatar
^ correct.
