Porsche Virtual Dyno Guide/Data Thread!
Well crap. lol
I tried to configure it before but no luck, so congrats! good job!
Loaded 3 runs with 2 different tunes and results were
0.8bar 405whp virtualdyno; 520hp crank dyno Superflow 800
1.8bar 725whp virtualdyno; 830hp dyno; supeflow800; lower timing tune
2+bar 704whp !!!! vdyno; 916hp superflow800; higher timing tune
the last setting was used to break 4s 60-130mph
I guess because of the MAP sensor limitation the vdyno can not show real hp for higher boost than 1.55bar unfortunately... this should be the case for Todd's car too, I would be curious to see, but I am quite sure the result will be lowered a lot as the app thinks we run only 1.55bar tops
I will try later to add manually the correct boost into the csv file and see how the results will change
Boost makes no difference in the calculation. It only uses RPM and TIME. The only reason the program reads boost is to graph it.
joseph_number1
Jul 19, 2018 05:45 PM
BlackMarketRacing
Dec 3, 2015 10:46 AM
Aug 20, 2015 12:17 PM
