Can someone rank the stock porsche Intercoolers for me
I know there are various stock type intercoolers I can use, can someone rank the below from best to worst or add any others that might be in the mix.
I'm considering a 997 IC but heard they arent that much better than the stock 996.
So we have
997.2 GTRS
997.1 GT
997.2 TT
997.1 TT
996 X50
996 GT
996 TT
I don't know which ones are the same and which are better than the other except that the base 996 TT is on the bottom... I want a plug and play IC where i don't have to cut or modify the stock shroud.
So we have
997.2 GTRS
997.1 GT
997.2 TT
997.1 TT
996 X50
996 GT
996 TT
996tt < 996 x50/gt2/997.1tt/gt2 < 997.2tt/gt2rs
i know there are various stock type intercoolers i can use, can someone rank the below from best to worst or add any others that might be in the mix.
I'm considering a 997 ic but heard they arent that much better than the stock 996.
So we have
997.2 gtrs
997.1 gt
997.2 tt
997.1 tt
996 x50
996 gt
996 tt
i don't know which ones are the same and which are better than the other except that the base 996 tt is on the bottom... I want a plug and play ic where i don't have to cut or modify the stock shroud.
So we have
997.2 gtrs
997.1 gt
997.2 tt
997.1 tt
996 x50
996 gt
996 tt
thank you! i thought the 997.2tt and gt2rs were same. it all can get confusing. i just know the 997.2's will be just fine for me.
Thanks Rob, so basically there are only three variants of the stock Porsche intercoolers?
996 x50 and GT2 are the same as 997.1 GT?
And all 997.2s ate the same?
Thanks this helps a lot.
^+1...yup!
#1 =996tt
#2=996X50/GT2 & 997.1TT/GT2, similar to above with extended 'finning' on core
#3=997.2 TT/TTS/GT2RS, better/finer core design
#1 =996tt
jump to 5:33
thanks for sharing the link, nice to see products tested with actual results...
Does make sense to me .1 vs .2 , higher heat-shed efficiency(higher/denser fin count) at the cost of flow(fins blocking flow)...all depends on your setup what will work 'best'
This is interesting, according to the Champion test the 997.2 flows less than the 997.1...
jump to 5:33
Champion Motorsport 2010 Porsche 997 Turbo Intercoolers - YouTube
jump to 5:33
I know that I've been told that raising flow can lower the amount of heat pulled so the converse would likely be true. Putting higher flowing larger inlets on a cooler and testing it back to back showed less IAT drop but higher flow\higher HP. Balancing act it seems, shame space is such a premium.
joseph_number1
Jul 19, 2018 05:45 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
