Can someone do me a favour? :)
Old Jul 15, 2015 | 06:03 AM
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
Originally Posted by YJosephTT
Maybe test the Map sensor plug with a multimeter, check for a short or grounding issue.
Has your engine ever been removed?
Ya, I'm going to test the outputs just to confirm the MAP is working properly but seeing that the gauge was affected by pulling the MAF plug I'm going to see if I can look at the short term fuel trims to see if they are good.
Old Jul 15, 2015 | 06:06 AM
NTIMD8's Avatar
Originally Posted by '02996ttx50
this may sound dumb but you did the reset calibration after unplugging/reconnecting the maf?
you've got some kinda gauge thing goin on. esp if you are now again hitting 1.2-1.3 and the car is performing as it should. but what do i know.. strange quirks indeed.
Ya I reset the TB every time I do anything with the TB, MAF etc.
The car is not performing as it should although it's way better than before. The boost just had to come on sooner and it will be perfect. Ita getting there so I'm not as discouraged as before.
Moogle
Mar 23, 2007 11:37 AM
