Will 997 werks1 intercoolers bolt up easy?
Old Jul 16, 2015 | 09:00 PM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
I'm looking at some werks intercoolers, what is needed to make them fit 996. I think I need some custom hoses?
Old Jul 16, 2015 | 09:16 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Easy is a relative term but yes, they will fit in the cages. You will only be able to seat 3 of 4 mouting pins (not a big deal) and you will have to trim the ducts. You are correct in that you will need a custom hose solution.
I ran the gen 2 2010 Cms coolers for a while which should have the same profile.
Are these the older werks 1 coolers with 12 rows or the later with 11 rows? (If its the older, you may be better off with Wagner or other options which come with the hoses and offer similar performance for a reasonable price -unless you're getting a screaming deal of course)
Old Jul 17, 2015 | 04:29 AM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
https://www.6speedonline.com/forums/997-turbo-gt2/368876-werks1-intercooler-install.html
Hope it's not the set in the link above. Just FWIW.
Old Jul 17, 2015 | 07:00 AM
YJosephTT's Avatar
Y
Thanks I think it's the first gen as it says werks not cms.
Do you know if the 997 IC assembly and mounts will fit in a 996?
Thanks it's not that particular set but looks similar
Old Jul 22, 2015 | 04:42 PM
YJosephTT's Avatar
They are the 12 row ones from what I can see.
Did you run them on a 996TT, if so what hoses did you use.
Old Oct 8, 2015 | 02:33 PM
YJosephTT's Avatar
Just an update if anyone comes across these Intercoolers.
I fitted the Gen1 Werks1 Intercoolers to my 996TT.
I used the Wagner Intercooler hose kits which fits perfect.
http://www.wagner-tuning.com/-NEW--S...996_p_179.html
A slightly cheaper option for hoses may be http://www.ebay.com/itm/371451577993
but they may be slightly shorter as the ebay ones are made for the stock intercooler couplings.
ID:	429972   Click image for larger version
Rez90
Aug 24, 2015 09:53 PM
pwdrhound
Aug 23, 2015 07:36 PM
