Wheel and tire size fitment help
Old Aug 7, 2015 | 05:04 PM
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
Originally Posted by '02996ttx50
what did the set set you back? if you dont mind?
Just went through tirerack so 1460 shipped.
Old Aug 7, 2015 | 05:12 PM
pwdrhound's Avatar
Originally Posted by flewis763
I understand that and it's good to a point depending on how much all around usage you want from a particular tire.
Here is a probabaly even dumper idea but has anyone run an 18 front and 19 rear? Many cars now days come with 1 inch larger rears so I don't see a big problem with it. Then I could get the diameter and wide wises and tire selection I'd like
265/35/18 front
305/30/19 rear
The overall size of the rear is 1 inch larger keeping that large contact patch like the 305/35/18 but with larger tire selection. Front I can keep the 265 for turn in and with the 25.3 diameter I won't have to mod the front much to prevent rubbing.
With those sizes I can get Hankook rs-3s for track use which I have been fond of in the past and for the price you can afford to be hard on them. Then lots of selections for normal steel tires as well
I would have no issues running an 18/19 set up, actually considered it myself if tire choice drove me to it. My suspension is set up around a 1" taller rear. The 26.3-5" rears are a win win compared to the short 315/30s. Better load rating, better gearing, larger contact patch, better grip.
Old Aug 7, 2015 | 05:22 PM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
Well car has coils so height adjust is easy. I think the 996 needs to be a little higher in the rear anyway. It always looks like to front is a little high.
I just can't believe that a 26.3 tire will fit fine but a 26.7 325/30/19 wont. I know it's a huge tire though. Ya a 18/19 setup for tire selection is looking way better
Old Aug 7, 2015 | 05:49 PM
'02996ttx50's Avatar
A bit more than the p zeros.. I'll try em one day
Thx
Old Aug 14, 2015 | 03:44 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Just my 2cents, but the optimal fitment for a 19" rear is 315x25x19. Unfortunately no one makes this size anymore except Nitto (pray a lot). Since I'm at GT2 ride height doesn't look like sticking with 19" is an option. I may have to drop back down to 18".
Old Aug 14, 2015 | 06:36 PM
flewis763's Avatar
Ya tires are just way to limited for that size.
Im going to put the car on the left next weekend (get here monday) and do some measuring. I found another guys running 325/30/19 rears and I think it's possible but at what cost. Lots of measuring.
Old Aug 14, 2015 | 07:53 PM
CBRacerX's Avatar
CBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to behold
{snip}
i got p zeros from tire rack at $347 per recently and even saw recently they had 315/30/18 at $196! per and that won't ever be beat for an N rated tire that was once an oem fitment. {snip}
When did this happen!?
To OP - Your idea of going staggered diameters is an interesting one.
Old Aug 14, 2015 | 08:59 PM
saw them on TR for that price. probably a closeout, but just after ( by a week ) i paid the usual 347 per. naturally
though i will say ( and it could be a coincidence though i rarely believe in them ) the last set of p zero rears with the RED logo looked great, and the newest ones i got although ( as rob correctly points out ) say they are made in germany. but given pirelli is now owned by a chinese company ( as if we aren't? ) they look certainly cheaper ( e.g. the lettering looks like something highly pronounced and "raised" ) and would look great on my old camaro, if the lettering were white but it's not.
so..weird looking p zeros going on a cpl days. meanwhile I'm enjoying drifting on my treadbare old ones
Old Sep 22, 2015 | 06:55 PM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
Choose your tires before and check if available into your sizes.
I will run MPSC2 probably in 19" for DD
245/35/19 and either 305 or 325/30/19, these are gt / gt2rs oem sizes
Will use 8.5(no 9"available) 53ET and 12"/51ET wheels,exactly GT2/GT3RS 997.2 offsets.
Guess for 325s will need new liners and a lot of tricks and work, having a taller tire would be nice for sure.
For best laps will try some slicks on OEM 18" wheels 9/11" and might sell my actual OZs
I run now MPSC2 225/295 R18 and have sufficient grip, will add some suspension upgrades soon and run more aggressive setup, used to run also 235/40/18 and 315/30/18 R888 - not going to use them again, good only for a few heat cycles, but good when new
tried some PS2 in 996gt2 size 235/315 R18 - hmmmm what I can say I put them just before the narrower MPSC2 and the difference was night and day... cornering, braking, etc
I guess 255 or 265 in front would be nice but not very easy to fit and drive for every day..
I will hunt for the 245/325(305) setup and will see from there, the gt2rs seems planted with those, the slicks will be xxx/645-18 most probably
Old Sep 24, 2015 | 06:51 AM
flewis763's Avatar
Ya I think I may end up with 245/305 combo. Still going to do some measuring yet but 325 might just be to much of a pita to fit. Might pick up a second set of 18s with 265 front 335 rear just for the track.
I have some 275/35/19 which are the same height as the 325s on my vr4 I was going to set in the wheel well and see how it looks.
COBB Tuning
Jan 1, 2025 09:02 AM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
WheelB
American Muscle
Aug 24, 2015 08:42 AM
ModBargains
Aug 20, 2015 12:28 PM
Aug 19, 2015 06:35 PM
