Finally solved my P0420/P0430 CEL issue
Old Aug 31, 2015 | 04:55 PM
aggk's Avatar
aggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud of
I've had an intermittent CEL over the last year or so.
Kept getting P0420/P0430 “Converter efficiency below threshold.”
Started to happen every 500 miles or so and got progressively worse. Till it was happening every 100 miles or so.
A month ago I found out I was losing coolant due to bad radiators.
I've put 1000 miles on the car since then with no CEL.
It looks like the coolant was getting down to the cats and burning off.
Doesn't look like it was my after-market exhaust at all.
Old Aug 31, 2015 | 07:01 PM
rmc1148's Avatar
Happy the problem is fixed but how did the coolant get from rads to cats= good distance..
Old Aug 31, 2015 | 07:06 PM
aggk's Avatar
I also replaced the coolant expansion tank at the same time for preventative measure. I suspect it might have been the coolant tank rather than the radiators as that's a long way for coolant to leak.
I know I dripped a bit the few times I topped off, which would explain the increased frequency of the codes over the last few months.
Just glad that it finally appears to be resolved.
Definitely shows the need for investigation rather than jumping to conclusions about the cats.
Old Aug 31, 2015 | 07:07 PM
'02996ttx50's Avatar
closest route would be the expansion tank breather overflow spilling onto them lol was there white residue on the cats or pipes at all? that would be odd. i get patches sometime on the my motor mounts from a drip or two and thats the source of it.
su_maverick
Sep 15, 2015 02:57 AM
Leslierc
Sep 6, 2015 11:52 AM
bmwtmx
Aug 26, 2015 07:26 AM
flewis763
Aug 24, 2015 07:07 PM
oddjob142
Aug 24, 2015 05:49 PM
