Suspension creak/noise
Old Sep 7, 2015 | 07:13 PM
Jlang's Avatar
Jlang is infamous around these parts
That's good to know that your problem was resolved. There's a lot of great people on here!
Old Sep 7, 2015 | 07:18 PM
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Originally Posted by Fishey
So, this might be the worst information I have ever read. A Indy shop can be excellent or it can be bad just like everything else in life it depends on the individual. However, a car forum is no replacement for having trained eyes physically look at the problem.
That being said like all good internet gurus, with absolutely no way of diagnosing your car over the internet except the information your providing. I mean, like absolutely no way to put your car in-front of me on a rack and turn it loaded on slip plates to track the noise and stethoscope the location to pin-point the cause. I am going to throw out an accurate diagnosis!
So, with the powers invested in me as an Internet Guru... You need to replace your Swaybar Endlinks.
https://www.fcpeuro.com/products/por...11-37643017381
Your Pal
-Fishey
Worst information you've ever read but you're a technician and you come here for information. Obviously you can't diagnosis a problem over the Internet but when most people explain their symptoms here, they are usually responded with spot on advice. Or else this forum would cease to exist if it was filled with the worst information ever. These guys gave me the most valuable information just from chatting a bit.
You're probably a good tech if you are on here but most techs who advertise themselves as Porsche "specialist" aren't.
Old Sep 7, 2015 | 07:38 PM
'02996ttx50's Avatar
[QUOTE=Jeanmarcboilard;4396748]Worst information you've ever read but you're a technician and you come here for information. Obviously you can't diagnosis a problem over the Internet but when most people explain their symptoms here, they are usually responded with spot on advice. Or else this forum would cease to exist if it was filled with the worst information ever. These guys gave me the most valuable information just from chatting a bit.
You're probably a good tech if you are on here but most techs who advertise themselves as Porsche "specialist" aren't.[/QUOTE/]
All true, and the lack of pretense that exists here with help from the Tims/sambos/todd's/SRM/markski/kevin-umw guy who give of their time and expertise daily way above and beyond what ordinary "shop" guys will regularly do since in many ways the more a mechanic can keep you in the dark with the illusions of "mystery", that surrounds the car as promulgated by a PORSCHE dealer that magically disappear once the door panels come off the more they stand to make via smoke and mirrors. that doesn't happen here.
Add to that the regular drivers like some of us! that don't know sh*t but learn once something happens, we remember symptomatically and how to fix it and share anecdotally our frustrations and eventual successes.
That's whats so cool about this place. You're right!
Old Jan 4, 2016 | 06:44 PM
BenTT's Avatar
BenTT is a splendid one to beholdBenTT is a splendid one to beholdBenTT is a splendid one to beholdBenTT is a splendid one to beholdBenTT is a splendid one to beholdBenTT is a splendid one to beholdBenTT is a splendid one to behold
Just reviving the thread
problem not solved yet.
I've had a top technician put the car in the air and cannot find anything creaking while in the air problem is now the temperature is gone cold the car is not creaking as often. That makes me think it could be something made out of rubber causing the problem. I did see there were a couple of other people that and said their cars made some more noises and it's embarrassing to have a car sound like a cheap hotel bed while you're going up and down the road.
Old Jan 4, 2016 | 07:01 PM
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
Are you sure they put your top mounts back together correctly? My car creaked when I installed my coilovers and found that it I was missing a piece of the mount. See the 2nd post for the link to that thread in the suspension link in my sig.
Old Jan 4, 2016 | 08:31 PM
gophaster's Avatar
gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !
I know this was mentioned previously but Have you tried disconnecting the sway bar links and/or at least making sure they are totally tight?
Old Jan 5, 2016 | 01:51 PM
BenTT's Avatar
I'll check out the top mount and sway bar links and see what happens
Old Jan 7, 2016 | 03:33 PM
BenTT's Avatar
Not the links or top mount either. My tech ruled out the shock itself which was his initial thought.
Old Jan 7, 2016 | 05:44 PM
hey,
if it makes ya feel ANY better? about 4/5 months ago i put in brand new oem bearing backing plates top mounts and here it is months later and i STILL i'm getting a crunching sound that was the same BEFORE i replaced them..and it AIN'T NORMAL! ( pissedd!! ) argh.
sp.. what's next?! i live with it. fkn tarret, they shoulda sent me camber plates that FIT! the 1st/2nd.. or THIRD TIME! grrrrrr! )..lol.. sorta ?!
Old Jan 7, 2016 | 08:16 PM
olwe's Avatar
olwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of light
I have the same problem.
My mechanic has just replaced my dead PSS9's with new PSS 10 front struts, installed new strut bearings, and new camber plates. The car is still creaking. This is very frustrating.
Old Jan 7, 2016 | 11:12 PM
"frustrating" is THE word. something just ain't right. how difficult is it to re-install top mounts! sheesh.
Old Jan 8, 2016 | 10:27 AM
BenTT's Avatar
It would not be difficult to reinstall them but the car made the noise before the top mounts were installed even though they were cracked.
Old Jan 8, 2016 | 02:56 PM
confused?.. are thinking you have defective/old parts..do you mean you put IN a "cracked" parts!? it can't ( or should't be!! ? )
( esp the rubber top mounts! ) or... ls it that you believe that maybe parts that are assembled/installed incorrectly? the strut mounts as you know have a fair number of parts that have to be assembled in the right sequence, of course you know this, but it it would be easy to put in a part in the wrong "sequence" of order was all i meant!! esp if one were "new" to the refreshing of the shock mounts etc.!
Old Jan 9, 2016 | 06:15 AM
BenTT's Avatar
to clarify the car had been creaking and the car had cracked upper shock mounts. The pair was replaced with a new pair and the car with silent for about a week after the replacement.
This was most likely due to the suspension being lubricated. I can spray down the entire suspension with WD-40 and get the car to temporarily quiet down as well.
Old Jan 9, 2016 | 09:12 AM
gophaster's Avatar
Have you considered maybe spraying down a section at a time, starting from the bottom to try and isolate to at least an area? Maybe worth a shot??
BTW, is it coming from one side or is it too hard to tell? If you do it in sections you might just find it
