Suspension creak/noise
I'm happy to report that my noise was coming from the front upper strut mounts (camber plates).
Here's the journey I went through for the repair.
https://www.6speedonline.com/forums/...endations.html
Later, Steve
Later, Steve
Creacking Noise on my GT2
my GT2 is starting to develop a creak noise on the front suspension. I've been doing some research on the OEM camber plates and noticed the i can actually source the monoball bearing from PMNA (part no. 9R133177900) at a cost of approx. $150 each.
So im thinking, should i get an Aftermarket (e.g. Elephant racing, Stomski, etc) or just buy the OEM monoball bearing and replace?? What do you think?
In my case it was the upper strut mount that had failed and needed replacing. My bearings wear fine.
gclasse,
Are you referring to the monoball cartridge like I installed I the upper strut mount or the bearing?
Later, Steve
gclasse,
Later, Steve
