Lets talk EBC Electronic Boost Controllers
Old Feb 27, 2016 | 12:23 AM
stv951's Avatar
stv951 is a jewel in the roughstv951 is a jewel in the roughstv951 is a jewel in the rough
Will be installing the Plex EBC on both my 996 TT as well as 3,8 993TT within the next 15 days
BEST EBC by far. I am lucky enough to be 500 meters away from the place they build these
John is an amazing guy. You should really try his products
Old Mar 11, 2016 | 08:14 PM
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Removed my Greddy ebc and installed the n75 in preparation for a new 1bar tune from Markski.
I've gone back and forth several times between ebc and ECU boost control. Hopefully, with this tune, this will be the last time I switch boost control around.
My Greddy was starting to act up as well, wiring harness plug wasn't always making contact and would shut the controller off until I wiggled the wires.
Old Mar 27, 2016 | 09:35 PM
Enclavet's Avatar
Enclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to behold
Anyone with the Plex PBC EBC. Does the device read Lambda from the OBD CAN or does that require more sensors?
Old Mar 28, 2016 | 02:00 AM
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
It does require separate sensors. You need to have sensors that they support plus cable extensions, because the engine is way in the back of our car.
The reason is that they listen to the OBD traffic between ECU and ABS/PSM unit and in that communication you don't find lambda values.
Old Mar 28, 2016 | 10:56 AM
Enclavet's Avatar
Looks like they have this product coming out. I'm looking for a monitor tool to view Lambda and Boost using the stock ECU. Hoping this allows that:
http://www.plex-tuning.com/supportdo...RELIMINARY.pdf
Old Mar 28, 2016 | 02:31 PM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
The plex supports lamba for several aftermarket afr tools, including aem. Your best bet is to install a 3rd party afr and then use the output to connect to the plex.
The big benefit is being able to setup a failsafe. If the afr goes lean you can reduce boost instantly.
Let me know if you need help. I have this setup in my car. Works flawlessly.
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
Rockinc1
Sep 30, 2015 06:44 PM
Ferrari
Aug 24, 2015 04:35 PM
