Who has best pricing on Coilovers? Bilstein pss9/10?
I am looking for a coiler setup that can handle ALOT of power and is good on the street. This car is not tracked.
I landed with pss9/10 but if anyone else has another suggestion its appreciated.
Anyone know who has the best pricing on them???
dont forget mounts, bushings (dog bones), etc.
all of it makes a HUGE difference with PSS10s (i have this setup and all associated parts)
believe i got from vivid racing. (have purchased ALOT of stuff from them over the years)
GL
GL
Depending on your ride height, you might only need the front drop links. I got perfect alignment settings (factory) with just the links and was at the lower end of the suggested ride height. I would suggest at least thrust bushings though given your power output.
FYI - Make sure they do the install correctly and use the correct top pieces to avoid the PSS 'ping' from binding springs.
https://www.6speedonline.com/forums/...-rotating.html
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
su_maverick
Aug 21, 2015 07:14 PM
