Long time poster...finally an owner
Old Mar 23, 2017 | 05:22 PM
  #46
HotRodGuy's Avatar
Need to throw some cquartz on them then they'll get on the car
ID:	472544Click image for larger version
Old Mar 24, 2017 | 06:16 AM
  #47
Sparrow's Avatar
Sparrow is infamous around these parts
Never seen wheels with Zinc coated hex headed face... I assume they're 3 piece wheels? I would think that's a lot of added weight, and how are they torqued down, looks too small to fit a socket in there...
Old Mar 24, 2017 | 08:27 AM
  #48
HotRodGuy's Avatar
They are cadnium bolts. These are some of the lightest wheels available. I think my 18x11.5 rear comes in at 19 lbs.
Torqued down with a socket....not too small
(That said, I didn't do them, my wheel refinisher did
Old Mar 24, 2017 | 09:40 AM
  #49
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
Congrats!
Old Mar 25, 2017 | 10:33 AM
  #50
split71's Avatar
split71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond repute
Originally Posted by brockster
Congrats!
Love CCW classics, can't wait to see them on the car! I agree with the cquartz sentiment for the wheels. My Kinesis wheels are ceramic coated and the almost zero brake dust is magnificent!
Old Mar 25, 2017 | 11:51 AM
  #51
HotRodGuy's Avatar
Sneak peak. Had to grind down the bore as there was too much powdercoat to fit the hub
ID:	472660Click image for larger version
ID:	472661Click image for larger version
ID:	472662Click image for larger version
Old Mar 25, 2017 | 05:00 PM
  #52
HotRodGuy's Avatar
ID:	472688Click image for larger version
ID:	472686Click image for larger version
ID:	472685Click image for larger version
Old Mar 25, 2017 | 05:19 PM
  #53
HotRodGuy's Avatar
May now name the car " the mullet"
Old Mar 25, 2017 | 06:11 PM
  #54
split71's Avatar
Haha..that last shot looks great! Did you add suspension?
Old Mar 25, 2017 | 06:18 PM
  #55
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
Looks great! What width/offset/tires did you go with for the rebuild?
Old Mar 26, 2017 | 05:44 PM
  #56
HotRodGuy's Avatar
Car came with PSS10's. I wish they would go lower....i'd like to get another .5" down.
With that, i'm on my 3rd front spoiler (and always have a reserve in house, lol)
Old Mar 26, 2017 | 05:52 PM
  #57
HotRodGuy's Avatar
My offsets aren't ideal. Rears were originally 18x10's.....i wanted to go 11's and got a good deal on 9" inner barrels vs doing a 2.5"outer barrel and 8.5" inner to get a better offset. So the rears are 18x11 with a 47MM offset, I'm running an 18MM spacer (and was on them when they were 18x10).
As we started taking them apart, one of the fronts inner's was cracked. To avoid the delay in waiting for CCW to ship new barrels (my first set took 3 weeks, my hardware took almost 6 weeks.....i ordered all new hardware, first shipment then sent me one nut, one bolt, one washer, lol). So I ended up putting the 8" rear barrels on the front making them 18x9 with what I believe is 55mm. I have a 3mm spacer up front.
Still running Sumi HTRZIII's. 225/40 - 295/30 I need to move the fronts up to 235/40's as they are a little stretched on the 9" wheel.
What i've also learned from this experience, don't buy wheels used and start ****ing with them.......
Old Mar 26, 2017 | 07:32 PM
  #58
cdk4219's Avatar
cdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to all
Yes, nothing more expensive than saving money on a set of used wheels! With as much powder coating as I see on the bore, hopefully it isn't that thick on mounting surface of the wheel. If it is, and the rotor gets hot, the coat may melt and the lug bolts can become loose.
Old Mar 26, 2017 | 08:05 PM
  #59
HotRodGuy's Avatar
Grinded off the back of the wheels a good amount as well
Old Mar 26, 2017 | 08:23 PM
  #60
pwdrhound's Avatar
The back of the wheel hub surface and the area under the mounting lugs must never be painted or powdercoated.
