What does this plug go to?
Old Dec 22, 2015 | 07:55 AM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
Here's the other side of the plug.
Old Dec 22, 2015 | 07:57 AM
jpflip's Avatar
Oil temp sensor just behind the oil filter housing?
Old Dec 22, 2015 | 08:03 AM
Nope, already connected.
Old Dec 22, 2015 | 08:04 AM
jpflip's Avatar
That was only a guess. Your car being a 2001, the wiring diagram is a bit difficult to see and to follow from page to page....There are not too many pink wires on this car, we will found it.....
Old Dec 22, 2015 | 08:16 AM
jpflip's Avatar
Do you have a tiptronic? I can see a solid pink wire going to the tiptronic transmission and coming from the transmission speed sensor????? Just for info....
Old Dec 22, 2015 | 08:26 AM
rmc1148's Avatar
Don't know but something not working or code should give a hint?
Old Dec 22, 2015 | 08:29 AM
No, my car is a 6 speed.
I appreciate the help.
Old Dec 22, 2015 | 08:30 AM
I'm just reinstalling the engine in the car after a transaxle rebuild and engine maintenance, so the battery is not connected.
Old Dec 22, 2015 | 08:32 AM
jpflip's Avatar
Dont get mad at me LOL!!!! On the picture I can see the pink wire but if you turn it is there any other color on this pink wire? Just to be sure.....
Old Dec 22, 2015 | 08:33 AM
rmc1148's Avatar
I see your dilemma now, flip will help.
Old Dec 22, 2015 | 08:35 AM
jpflip's Avatar
Just saw your post mentioning "14" mentioning a solid color....Sorry.
Old Dec 22, 2015 | 09:32 AM
jpflip's Avatar
It is really frustrating because there are not too many units with two wires plug and none with a solid pink wire as per 2001 wiring diagram that I have. I also double check with the 2002 wiring diagram and still the same....
Lets consider we have a two wire plug with a red/blue wire. This plug can be connected on
1: intake pipe change-over valve.
2: Camshaft adjustment solenoids , both side...
3: secondari air valve.
4: N75 valve. (also white/green)
5: tank vent valve.(also violet)
6: both solenoids for valve lift. 4-5-6 (white/green) 1-2-3(white/red)
OMG can it be violet instead of pink?????
Old Dec 22, 2015 | 09:41 AM
jpflip's Avatar
Looking to found this tank venting valve..... I thought it was not in the engine compartment.....
Old Dec 22, 2015 | 10:22 AM
jpflip's Avatar
Some more info for a possible location:
Name:	Screen Shot 2015-12-22 at 12.21.57.jpeg
Old Dec 22, 2015 | 10:49 AM
jpflip's Avatar
I think this is the plug position you are looking for!!!! Tank venting valve!!! A red/blue wire and a violet wire!!! This one looks good But probably difficult to reach. May be you should lower the engine a little bit (4 inches) to reach it.....
Name:	Screen Shot 2015-12-22 at 13.19.18.jpeg
