Rear Wheel Bearing Experience??
Old Jan 11, 2016 | 07:42 PM
mk19's Avatar
mk19 is infamous around these parts
I'm hearing what I think is wheel bearing noise from the rear of my '02 996tt that has ~130k miles.
I can't feel any movement in either wheel on jacks, but then I couldn't feel it in the fronts that I recently replaced.
In the front, I couldn't hear or feel any play but upon replacing the shocks, I pulled the knuckles and on once in hand, one it felt rotationally rough, the other was down right sloppy. I replaced them.
Any experience/advice would really be a appreciated.
TXX,
MK
Old Jan 11, 2016 | 08:21 PM
'02996ttx50's Avatar
x posting for the other thread assuming it's yours?
in any event:
all i remember it as was as a low pitched and consistent and very low frequency low pitched whine/rumble and when you can temporarily diminish if not eliminate it while slaloming while turning hard left/right. when the wheel was turned left at low speed ( IIRC?? ) it would go away and it was the right rear wheel bearing ( again, IIRC? ) was bad. the "slalom" was they key to identifying the sound/issue. for, me of course.
gl wi it!
Old Jan 12, 2016 | 12:12 PM
mk19's Avatar
Thanks ttx50. Great info, I'll try it.
IIRC? means what??
Old Jan 12, 2016 | 12:59 PM
rmc1148's Avatar
At 130k its time either way so replace.
Old Jan 12, 2016 | 05:15 PM
BLKMGK's Avatar
If I ReCall
Old Jan 12, 2016 | 11:32 PM
IIRC? means what??
IIRC = "if i remember correctly". I'm just up at the kanan tunnels or las virgenes - decker cyn- the snake... pick one.. if you ever need to trap speed to the 101 ( just kidding!!
Old Jan 13, 2016 | 01:27 PM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
Just pray it's not the input/output shaft bearings in your transaxle.
Old Jan 16, 2016 | 11:40 AM
mk19's Avatar
ttx50;
Yep.........the noise change with the slow speed slalom I'll let you all know what I find when I get in there.
Thanks again.
Old Jan 16, 2016 | 05:38 PM
ttx50;
Thanks again.
NP..it usually does, if it's indeed wheel bearing related. remember, can always meet at that top of or below @ pch e.g. any of the canyons from pch to ventura county line are minutes away ( no traffic : ) have a quick listen if this issue persists, absent a conclusive determination. quick listen is usually all ya need. GL!
mavila
May 2, 2016 02:24 PM
gadangit
Dec 28, 2015 03:28 PM
hroussard
Dec 17, 2015 12:18 PM
Zmydust
Dec 13, 2015 06:36 PM
