divert value to ?
Old Jan 22, 2016 | 09:53 PM
Pucky's Avatar
Pucky is infamous around these parts
divert value to ?
Hi All,
I've purchased a 2002 996 Turbo (Arctic Silver) a few weeks ago I'm needing some help to clarify some missing pieces.
The car was heavily modded (larger throttle body from a cayenne turbo, custom y pressure pipe, turbo smart blow off valve, custom air intake), it's it's blowing codes including the PSM/ABS lights flashing.
I purchased a leak tester and have found many leaks (passenger side pipe from turbo to inner cooler, driver intercooler weld, hole in weld of custom y pipe, oh and blow off valve full open) and I'm wanting to get this car sorted. I'm replacing the throttle body back to stock, replacing custom y-pipe which includes blow off valve back to stock and I've picked up new EVOMS boost pipes, diverter valves (since they were removed), F-Pipe and new EVOMS intercoolers.
As part of reinstalling the diverter valves I had to get the y-piece that they plug into. I've noticed it has 4 connections, 2 for the diverter valves, 1 for a vacuum back to throttle body and another large hole for something.
My question is what is that something? Does the y-piece that holds the diverter valves plug back into the intake manifold which is located down near driver turbo intake?
I've got all the hardware and waiting for a sunny weekend to start this, but need to make sure I've got it all planned out.
Any help is much appreciated.
Old Jan 22, 2016 | 10:28 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
The diverter Y goes back into the airbox to turbo inlet pipe
Old Jan 22, 2016 | 10:38 PM
Pucky's Avatar
Ah ok, something else that was removed.
@993GT does it plug into 99611062272
#11 on diagram
Thanks so much!
Old Jan 22, 2016 | 10:45 PM
993GT's Avatar
Yup that's it!
If you need any pics let me know
Cheers,
Rob
#11 on diagram
Thanks so much!
Old Jan 22, 2016 | 10:46 PM
Pucky's Avatar
Yup that's it!
Cheers,
Rob
Thanks dude. Huge help!!
Old Jan 22, 2016 | 10:48 PM
993GT's Avatar
Happy to help
Good luck with the car!
Old Jan 23, 2016 | 03:51 AM
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Congrats and welcome to the club.
Best way to learn about these cars is to buy a not-so-well sorted car and digging into it to make it run right. That's what I had to do. Parts diagrams will be your best friend.
Good luck
Old Jan 23, 2016 | 07:32 AM
32krazy!'s Avatar
aside from all the leaks was the car tuned? are you running a mafless tune? instead of replacing all the modded parts with stock parts which may not play well with a tune. why not sort the leaks find out about the tune and keep the what sounds like a mafless setup? if theres no maf and you don't have a mafless tune this could be the source of all your codes
Old Jan 23, 2016 | 02:54 PM
Pucky's Avatar
Stock ECU no tune, maf was moved way to the back of the engine bay, close to where the intake splits to each turbo intake.
The fact that all this stuff was added with no tune is so confusing. Previous owner was not a Porsche guy, but liked to tinker.
Old Jan 23, 2016 | 03:08 PM
32krazy!'s Avatar
that sounds like the base of all the issues. get a mafless tune from srm and unplug the maf. having moved the maf and making all those intake changes with no tune is a recipe for codes and problems.
Old Jan 23, 2016 | 05:42 PM
Pucky's Avatar
I've got a Cobb AccessPort v3 so I'll give that a try after I fix the leaks. Thanks
Cuda911
Dec 21, 2015 06:51 PM
Red911TT
Dec 10, 2015 10:54 PM
Grey Goose
Dec 6, 2015 02:16 PM
carwash
Dec 3, 2015 09:14 PM
