Where does this vacum pipe go??
Old Mar 2, 2016 | 09:00 AM
krikra's Avatar
krikra has much to be proud ofkrikra has much to be proud ofkrikra has much to be proud ofkrikra has much to be proud ofkrikra has much to be proud ofkrikra has much to be proud ofkrikra has much to be proud ofkrikra has much to be proud of
While installing my COBB 1000cc injectors I managed to pull this vacum pipe of a hose.
The solenoid was mounted on the Secondary Air Injection pump. While removing the solenoid from the SAI pump I managed to pull the pipe off before I could see where it came off.
I located this vacum system drawing and I guess I need to locate that red circled vacum connection. But havent been able to locate that X-hose..
Hoping that some of you Guys recognize and can let me know where to find it
Considering removing the whole damn SAI system now that I am in there anyway..
Old Mar 2, 2016 | 09:27 AM
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
I was just in there securing all my vacuum pipes with small tie wraps last night. That X-pipe is tucked in there under the throttle body and behind the A/C compressor. But it's also behind a wiring harness and fuel pipe.
This may help:
Old Mar 2, 2016 | 10:08 AM
krikra's Avatar
Thanks pteck,
Thats exactly what I needed!
jetfuelonly
Mar 2, 2016 07:37 PM
Thered300zx
Feb 13, 2016 06:23 PM
pteck
Feb 8, 2016 12:56 PM
speedracer800
Feb 6, 2016 10:48 PM
