Gearshift lever at transmission
The Cup lever is what is used on both the 6GT2/3 and 7GT3.
Thank you John. Thinking to do this when I do the LSD. I know it is more work, but if trans is coming out anyway....
It's actually not much work with the gearbox out. Probably 1-2hrs labor. You will also need the shift cable bracket which is bolted to the outside of the gearbox to properly align the cables with the shorter lever.
i did it on mine but havent had any chance to try driving it yet
I did it on mine. Shifts are more notchy, faster and lighter feel. Not as smooth as or lazy as with counter weights. If you drive aggressively it's worth it, if yours is more of a gt car I'd leave them.
as an fyi its a countersunk torx bolt that held my weights in. took all of 30 seconds to strip the heads on both! had to drill them out to remove the weights. since the trans was out it was a simple fix for the bolts. if the trans is in the car it may be more difficult if the bolts strip
since the nature of 2nd gear popout is improper shimming at the gearset removing the weights should have no effect on popout
Macan Vendor Classifieds
Mar 31, 2016 08:28 PM
