Best launch Technique for a Tip
Old Dec 15, 2005 | 06:17 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Thinking of heading to local track to lay down some 1/4 miles...
Can someone tell me the best technique to ensure a nice responsive start for a Tip?
Old Dec 15, 2005 | 06:58 PM
sharkster's Avatar
Easy...
Put it in 1st gear manually. Turn off the PSM. Push the brake pedal ALL the way with your left foot. With your right foot press the accelerator (fairly hard) to hold about 2800rpms or more (unless it brakes loose). Use the hand brake for more force if need be... Then let go of the brake and simultaneously floor the gas. Make sense?
If you have non-stock brakes you can do more...
Old Dec 15, 2005 | 07:50 PM
PorschePhd's Avatar
Just don't be a chucklehead and pull the ABS/PSM fuse. Right Alex!
Old Dec 15, 2005 | 07:59 PM
sharkster's Avatar
Heheh You could do that... I highly recommend everyone try that at least once (actually please DO NOT do that).
I still need to post that video sometime. The commentary is priceless...
Old Dec 15, 2005 | 08:45 PM
PorschePhd's Avatar
I had such a bad headache I couldn't say anything!
Old Dec 15, 2005 | 09:38 PM
brn2bn1's Avatar
brn2bn1 is infamous around these parts
So what exactly happends when you pull the fuse?
Old Dec 15, 2005 | 09:43 PM
sharkster's Avatar
You and me both! I'm not sure what was worse. The night before the fact or the day itself? I know for a fact, I am NEVER EVER going to vegas again
Old Dec 15, 2005 | 09:44 PM
sharkster's Avatar
Um.. with my brakes the way they are the car goes into a 360-720 pretty darn quickly.
Old Dec 16, 2005 | 12:15 AM
Sounds pretty exciting, so how much free radius do you need?
Btw, thanks for the info.
Old Dec 16, 2005 | 02:53 AM
does anyone brake torque the 6 speed MT at the track?
... with the hand break.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 16, 2005 | 08:15 AM
CarreraGtRacer's Avatar
CarreraGtRacer is infamous around these parts
put the car in neutral/rev/stick it into drive??
Old Dec 16, 2005 | 01:28 PM
Think I will stick with Sharky's way, but I might try the fuse thing!
Not!
Old Dec 16, 2005 | 02:08 PM
sharkster's Avatar
heeeeeeeeeellll no!
Rguy
Apr 12, 2020 11:11 PM
MadWhip
Sep 13, 2015 01:27 PM
ECS Tuning - VW
Sep 8, 2015 12:54 PM
rohnin
Sep 7, 2015 01:10 PM
