Post your logs
Old Mar 23, 2016 | 12:34 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Well my 16g never dropped off like that if they did the timing would not advance like that. Im not sure what would cause that but when numbers go up then drop 1 point then go back up thats where timing is pulled and you have knock. I had that happen on my second to last log month ago and fixed it.
I thank Tony at EPL hes really has some good tunes.
Old Mar 23, 2016 | 12:37 AM
996tt550hp's Avatar
Which line is your boost on? The second to right or the third one on the right?
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Looks like you stopped at 6400rpm. Ours look pretty similar up until then. I wonder what yours would look like from 6400-7000 rpm. Not that you should go log that, that's a range I usually never drive in. I'm surprised I let mine get that high.
Old Mar 23, 2016 | 12:38 AM
My boost is second from the right.
Old Mar 23, 2016 | 12:39 AM
996tt550hp's Avatar
I have one that goes further but it never went passed 16.
Old Mar 23, 2016 | 12:41 AM
996tt550hp's Avatar
You know your running over 1.3bar? You hit some 1.33bar which is 19+ psi.
Old Mar 23, 2016 | 12:48 AM
Interesting. I'll ask Markski about it. I'm sure he'll have an answer. Good chatting with you, I learned a few things. Hopefully others will post some of their logs too for comparison.
Old Mar 23, 2016 | 12:51 AM
996tt550hp's Avatar
Your welcome but marski knows way more then me. You could be running more boost because of cold weather. But at 2300 log is 1.3bar most if the time. My last log i did was 2230 average boost.
Old Mar 23, 2016 | 01:00 AM
Sorry, my mistake, my boost is on the left side of the 2 boost reading. The one on the right is boost setpoint. So mine's a bit lower. Max 1.2bar. Still too much for my injectors so I'm getting a 1bar tune.
Old Mar 23, 2016 | 01:11 AM
996tt550hp's Avatar
Ohh ok your highest reading was about 1.23bar
Old May 18, 2016 | 11:02 PM
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
Just got a cable and did a few pulls today. Am I missing anything important to log? Anything I can get rid of? Anything look out of range?
File Type: xls
Old May 19, 2016 | 08:02 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
3rd gear #1 - Looks good ^^^^. Safe and Conservative...maybe a little too rich for that boost pressure. Timing is conservative as well.
4th gear 1 - same.
Are you on pump gas only?
Old May 19, 2016 | 10:50 AM
Aktavate's Avatar
Yes sadly on 91, nothing too exciting just epl flash, injectors and turbo piping. Thank you for taking a look!
Old May 19, 2016 | 10:58 AM
03EvoIII's Avatar
yea NP!
saabin
Mar 16, 2016 04:57 PM
Scrambler8
Mar 1, 2016 10:06 AM
socialpro
Cayenne 958
Feb 28, 2016 11:45 AM
